Question about GE JVM1630 Microwave Oven
Replace door hinge on JVM1533WD002
My wife broke the door hinge on our microwave and we called GE to send us the replacement part. Would someone be able to explain to me how to replace the broken hinge?
    Scholar:
  • 43 Answers
Door Hinge replacement requires a Microwave Radiation Leak Test be performed after repairs.I am surprised they would sell you the part knowing this. You should have this repaired by a professional for SAFETY sake.
Posted on Jan 28, 2008
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replace door
If you're replacing the entire door, this is a very simple process that only requires you to open the door all the way and lift straight up at the hinges. The door lifts off the hinge pins, and the new one can be reinstalled by aligning it back on the hinge pins. (You may have to remove the hinges from the old door and install them on the new one on some models). NOTE: In some cases you may have remove the upper grille guard to accommodate lifting the door. The mounting screws for the guard on located across the top of the oven. If you only need to replace the door handle, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 26, 2011 | GE Spacemaker JVM1540 Microwave Oven
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The handle broke off of our GE spacesaver microwave. i got a replacement handle but i cant figure out how to take the door apart. anybody have a suggestion?
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
On the GE JVM 1650 Spacemaker microwave, how do I replace the door?
If replacing the entire door, all that is required is to open the door all the way open and lift straight up on the hinge side of the door. The door will lift off the hinge pins. You may have to remove the upper grill cover (if equipped) on some models for better access. If you have questions, please let me know. I hope this helps you.
Sep 24, 2009 | GE JVM1650 1000 Watts Microwave Oven
Door is hard to open
you can solve this yourself by removing door pins and straighting the hinges
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1630 Microwave Oven Logo
333 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
