DENON AVR-1500 "PROTECT" appears on display
I have a DENON AVR-1500. It worked great until I got a static relayed shock when pushed the power switch. Now after the initialization process, "PROTECT" comes up on the display. The manual states that the speakers are short circuited or the ventilation holes are blocked. I checked both and this is not the cause. Any Ideas?
  • jim_mary2002 Jan 30, 2008
    No luck, as I mentioned in my original message it is not the speaker wires or venilation. I think I fried something with the static when I touched the power switch. I had the receiver over 12 years - so I don't want to put a lot of money into it. I will see what I can pick up on ebay for ~$200.
    Thanks,
    Jim
  • 36 Answers
Hi there!
all i can do from your description, is to give you some of my views. so, don't vote me anything, except "faxya".
as you described, the speakers are ok, and ventilation holes have no problem, then, the problem lies with the Denon itself. the static may have hurted the "protection logic". do you know how to change its logic IC or to ru-burn the MCU(micro computer unit) and you do not have the unconteminated logic program anyway? i guess not. Not even the agent's servicemen can. It has been a long time servicemen are spoiled or hands tied up by the VLSI(very large size integration), so they just find out which PCB is in question and change the whole PCB, just like car service centers do. very costly to our wallet and to the environment!
pc-cook
Posted on Jan 28, 2008
    Guru:
  • 1,894 Answers
Protect?
  • 9 more comments
  • dewan nafees ahmed Jan 28, 2008
    two cables of a speaker were touching each other.
    this may be the problem
    else
    the radio output (stk428-610 & stk428-640) are bad, for this in the panel you can see protect change....
    the STK outputs will be $65.00 each
    good luck..
    It is either an issue with having a surge protector connection. u plug in the receiver into wall without protector.. see if any change..
    ok good luck..
    but remember The first thing I’d check is all the speaker wire connections. If you have bare wire connections to the terminals, a single stray strand touching the other speaker terminal can activate the receiver’s protection mode. This is true for both ends, the receiver and the speaker. Also, on the receiver end, if a stray strand from the positive terminal touches the chassis, that could also trigger the protect mode.
    even if any of these things dosent work for you.. then replace all of ur speaker wire and move it to a more ventilated area and things have to be OK for sure..
    else means calling a tech will be ur last option..
    thank you.. good luck
  • dewan nafees ahmed Jan 30, 2008
    what happened?
  • dewan nafees ahmed Jan 31, 2008
    also 12 years. huh.. enough.. its very old one..
    ITS BEST THAT YOU CAN OPT FOR A NEW ONE WITH MANY NEW FEATURES.. SONY IS GOOD..
    but do read many ratings and reviews before you go and buy it.. a one hour survey and home work made by you in bnuying it will fetch you a very good product..
  • dewan nafees ahmed Feb 05, 2008
    did solution work?
  • dewan nafees ahmed Feb 07, 2008
    what happened?
  • dewan nafees ahmed Feb 08, 2008
    thread closed or not?
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
There's an electrical problem! The unit shuts off to protect itself. the relay sound is normal and is part of the power supply - good quality amps have them. I suggest taking it to your local repair shop.
Feb 17, 2015 | Denon AVR-3313CI
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Denon AVR 2105 5years old has worked perfectly. Now all of a suddend Zone 2 does not come on. Any ideas why after working perfect for so long?
Bad button on the remote? or
static discharge from being touched can cause all kinds of strange problems.
I would reset the micro processor back to default settings..
RESET PROCEDURE
1. PUSH MAIN POWER SWITCH OFF
2. WHILE HOLDING THE FOLLOWING KEYS DOWN, PUSH MAIN POWER SWITCH ON
AVR-2105 or AVR-885 Front Speaker A and B (2 keys)
Let the front panel blink 3 or 4 times and then release the keys (buttons)
You will have to do your set up again i.e. speaker size, assign inputs, FM presets etc.
Aug 25, 2013 | Audio Players & Recorders
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
I have a denon AVR-1604. It was working fine but started to hear a relay clicking on and off as it was playing. Now when i try to turn it on from standby i hear the relay click as i turn it on with the...
the noise is the speaker protection switch ( reset relay) disconnect all speakers see if it stops if so then conect speakers 1 by 1 untill you find the crossed speaker could just be a crossed wire best of luck
get me back if you need more help
Dec 31, 2010 | Denon AVR-1604 Receiver
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Denon AVR-683 won't stay on
hope this helps?
Jul 24, 2008 | Denon AVR-683 Receiver
153 people viewed this question
 Grubhead
Grubhead
