Vw beetle 93. My alarm goes of intermitantly do i need a new door lock ?
I just did this to my 02' last night.
Put key in ignition and turn to run. Open and close each door, make sure the interior lights and dinger go off each door. If one doesn't that is the door to focus on and do this......
Open door.
With a screwdriver trip the latch on the door 2 clicks, you'll see
In the void just below the latch finger get a can of Brakecleen and firehose the hell out of it. As fast as it evaporates I still had it running out of the door drain.
Pull the handle to re-set the latch and open and close the door several times to work the switch. Might have to do it several dozen times.
Repeat as necessary.
Finish up by giving it a blast of PB Blaster, WD 40, or some light lubricant.
Repeat for the other doors.
If this didn't do the trick, give it a few days to maybe work itself free, ohterwise you may have to replace the $170 lock assembly.
