Hi
I have a Lexmark all in one printer and have just upgraded to Vista. I have been able to download Vista drivers for the printer but the scanner doesn't work. Is there a way around this?
Thanks
Experienced the same problem.
The Dutch importer suggested to try photogallery, but was not sure of it. Howevr it proved to be the solution.
Open <windows photogallery>, then <files>, click on <import from camera and scvanner>, then click on <import>.
If your printer is switched <on> it now will start scanning and send the result in your file <pictures>, normally on your C:disc.
I just tried it and it functions well, at least in black-and-white.
Still have to check the color scanning, but that will probably no problem either.
Hope to have helped you, yours GerritDelden.
How do i use my scanner on my lexmark p6350 printer now ive switched to vista please help...
Salut a tous j'ai trouver pour lexmark p6350 :scanner
1) panneau configuration _ 2) clic sur "scanner et apareils photo" _ clic sur alouter un péripherique et puis apres suivant continu en cliquant sur terminer (première étape terminer)
installing lexmark P6350 with Windows Vista CD won't install
Thanks for that. I have gone back to XP (for other reasons) but will try your solution when I next use Vista
I download the driver for P6350 all n one and it will work with Vista. I need the driver. Please help
i can not get the software to load on a computer with vista
lexmark p6350
My scanner isnt working , copying etc is fine but the scanner wont scan to PC
will not scan to the computer
