Question about Swintec 7040 Typewriter
Margin locked Cannot move margin past 20.....(Right Margin) How do I release or re-set........... space bar won't go past 20 either
  • hremail455 Jan 29, 2008
    Nope......didn't work.
    I can move the carrier by hand
    It goes back to the (5) position for the Left hand margin
    when I hit the space bar it moves and stops on 20....
  • leonormklady Jun 03, 2008
    my left margin resets itself everytime i type to about 5 characters from the last word typed--how do i clear up all the margins and tabs--it's confusing-i don't have a manual
Apparently there were other margins set in higher range.
I started backward and repeated your process and it cleared all 4 set positions.
I didn't give up.......
I've finally cleared the right margin set at 20.
Thanks,
Posted on Jan 29, 2008
  • 3 Answers
Hremail455, I had the same problem. Press and HOLD Mar Rel and then press and hold the Right (->) button until it gets to the margin setting you want.
Posted on Nov 01, 2008
  • 478 Answers
Check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
Right margin will not release Can get to a certain point and it just locks up - Does this have anything to do with the Reloc button which I don't know how to use.
the RELOC button is for when you go back and make a correction, after you make the correction you hit the RELOC button and it will automatically go back to where you left off. if you are typing along and it stops typing and won't go any further, you are at the right margin. if you want to go past this point, you have to hit the MAR REL button. then hit the space bar or keep typing. if you want to move the margin, move the carrier to where you want the margin and hit R MAR, and that will set the margin at that point. works the same way for the left margin.
Mar 05, 2011 | Brother Office Equipment & Supplies
Setting nargins
The keys used for margin control on the brothers is the ALT key just to the left of the space bar, and the #3,4,& 5 keys.
To move outside the present margin to the left, backspace to the left margin. Press the ALT and '3' keys at the same time to bypass the margin. Back space past the margin to the point where the margin is to be set. At the point you want the new left margin, press the ALT and '4' keys at the same time to set the new left margin.
To move outside the present margin to the right, spacebar over to the right margin. Press the ALT and '3' keys at the same time to bypass the margin. Then spacebar over to the point where the new right margin is to be set. Press the ALT and '5' keys at the same time to set the new right margin.
The basics are that the ALT +3 releases margins, ALT +4 sets the left margin at the point of the carrier, ALT + 5 sets the right margin at the point of the carrier.
Hope this helps.
Mar 15, 2010 | Brother ML-300 Typewriter
Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Aug 20, 2009 | Brother ML-100 Typewriter
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2008 | Brother EM-530 Typewriter
Unable to set margins
To set the Left margin:
1) Move the carrier ro the place you want to set the left margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current left margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[L MAR(4)]. The left margin is now set.
To set the Right margin:
1) Move the carrier ro the place you want to set the right margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current right margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[R MAR(5)]. The right margin is now set.
That is directly out of the manual. I will upload the manual to FixYa, and you will be able to view it from the ML-500 Typewriter's product page: http://www.fixya.com/support/p131634-brother_ml_500_typewriter
-John
Feb 06, 2008 | Brother ML-500 Typewriter
Brother ml 100
when the typewriter is first switched on the typewriter will automatically set a margin 10 or 12 spaces in,depending on which pitch setting you have. To set a margin say on 20,space-bar in to 20 on the spacing scale and then press Margin Set Key. to set a margin on say, 5 first depress the Margin release key and back-space 5 spaces in and then set then margin as before. Remember that the typewriter will "forget" the settings as soon as it is switched off.
Oct 29, 2007 | Brother ML-100 Typewriter
Swintec 7040 Typewriter Logo
319 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
