Front Load LG Washer and Dryer Pedestals
Purchased LG Front load washer and dryer. Since my laundry room is on the main floor Store adviced against pedestal purchased as vilbration may cause structural damage. Please advice
    New Friend:
  • 60 Answers
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Posted on Jan 28, 2008
Are LG washer/dryer pedestals a bad idea? We have an LG washer and dryer in our garage on concrete and have no issues with vibration. We recently purchased the pedestals for these and have been warned...
On a concrete floor these pedestals have a greater success than any other flooring. Nevertheless, more shaking will occur. One solution that has worked is installing "shake away" rubber pads with the pedestals. Not sure if there's an appliance parts store near you that carries this product. But like I said earlier, the fact that they are on a concrete floor helps.
Sep 28, 2011 | LG WDP4W 14 inch Pedestal White
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
JUST GOT A NEW FRONT LOAD DUET WASHER - 3.7 AND IT IS KNOCKING AND MOVING ACROSS THE FLOOR. IS THIS A PROBLEM WITH THE MACHINE OR WHAT?
check to see if the shipping rods have been removed,also if machine is located on upper floor laundry room,the floor may not be sturdy enough to counter act the force generated during spin,this is a common issue in newer homes
Mar 10, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Whirlpool Duet washer is off balance.
My wife and I just purchased the Whirlpool 9400 series washer and dryer. We loved the pair, the installers came in and set them up ran them rather quickly and showed us the features and left. We put our first load into the washer, I will add, it was a rather large load, but nothing bigger than what the washing machine would handle. Started the washer up and walked away. About 30 minutes later we walk back into the laundry room to see and hear the washer rocking the pedastle door right out of the pedastle and then started to walk itself about 12 inches from the wall. This was very dangerous to us as we have a 14mth old. We immediatly called the store who sent another installer over. He again checked it for levelness and said that this is a known issue and that we should consider buying the cabrio or taking the washer and dryer off the pedastles.
So, to solve this issue, I'm sure you are all waiting. Infact, the washer was level, however, and this is what I found to be key, Lift the washing machine off the front legs, raise them up about a 1/4" higher than the back legs, this will make the washer uneven from front to back, but the other key is to make sure that the nut on the washer leg is all the way up and tight against the washer. In my user manual it said use a 17mm open end wrench to lock the nut against the washer, but my nut was a 14mm.
Again, make the front of the washer a little higher than the back and make sure all the nuts that are on the washer legs are tight against the washer or pedastle.
My washer went from the house ********, to the thing that doesn't make any noise at all.
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
Feb 28, 2009 | GE WBVH6240F Front Load Washer
Maytag Epic Z
heres a product that might be helpful http://www.apwagner.com/index.php?main_page=product_info&products_id=148095 really had good results with this since inroducd a year ago, $ 30 bucks its worth a shot!!!!
Oct 17, 2008 | Washing Machines
Shaking like crazy
ALERT. transit brackets still on machine ..REMOVE THEM;;
Nov 25, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
945 people viewed this question
Top Washing Machines Experts
