Question about Refrigerators
Amana bottom freezer
2 year old Amana  bottom freezer keeps icing up on back wall of freezer and wont stay cold enough for ice cream and such but is cold enough to keep ice.... I have thoroughly defrosted and seemed to work for month or so but started icing up again and not keeping cold enough again!
  • Anonymous Mar 29, 2014
    My amana fridge with the freezer on the bottom isn't defrosting properly it keeps icing up the fridge is only three years old what could the problem be and how can I check it
    Novelist:
  • 130 Answers
Hello ghilitho, what you are having is an issue with the defrost cycle. There are 3 parts to this, heater, thermosat,and timer. Sometimes on the newer units the timer is the electronic control. What you are seeing is after you defrost the unit, it works for a time, this is because the evap fan pushes the air thru the unit. With the evap coil froze solid, the cooling drops. You will need a ohm meter to check the heater and thermosat, the heater & thermosat should show to be closed. Also make sure if this unit has a over heat thermosat that it is closed. It may have open up. If all this is good, then the timer is the issue. Hope this helps
Posted on Jan 28, 2008
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Amana side by side model DRS2362A. Recently the freezer is not staying cold enough to keep ice cream frozen. Tried cleaning out underneath (grill area) but this hasn't helped. Other foods seem to be...
If you see frost behind the back wall or begin to notice the fresh food compartment getting warmer then you might have a defrost problem. The defrost system is a heater and termination thermostat inside the evaporator and A timer. The termination thermostat shuts down the heater when it gets to be warm enough for the frost to melt. It is important for the thermostat to kill the heater because the defrost mode is 21 minutes long.
If that heater was to stay on for 21 minutes the ice box would be severely damaged. The Timer might be hung in the run mode and not jumping into defrost every 8 or 10 hour as it should. The heater element might have gone bad or the termination thermostat might be swollen and failed. That is some ideas to check. Service manual
Jul 16, 2010 | Amana Refrigerators
Amana ABB2224DES - 5 years old - freezer is not keeping ice cream frozen it is mushy - the freezer setting has been set on 6 for a long time
Check temp. should be around 0. If not check to make sure condensor fan motor is working. Check condensor for lint. Do not put ice cream in door shelfs this is the warmest point in freezer. if has a icemaker, check to see if ice in bucket has a wet look or dry look. Wet is a not cold enough. dry is cold enough. If refrig is cycling of and on and temp is 0 , ice dry... possible bad thermastate/ sensor.
Mar 05, 2010 | Refrigerators
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
