Question about 2wire 2700HG-B Router (2700HGB)
2Wire 2700HG-B No DSL Signal
The modem was working great until a tree came down and took out our power. We did not lose our phone service but after the power was restored the modem could not find a DSL signal. The phone company is now renting us a modem only and our Linksys router keeps dropping out. Is the 2Wire repairable or is it toast? It appeared to be working okay after we got our power back, but it just couldn't find a DSL signal. I tried a different phone cord, but that didn't fix the problem. I took the top cover off just now hoping there was a fuse in the phone line circuit, but if there is, it's on the underside and I haven't taken the screws out yet. I have limited electronics knowledge and a soldering iron, if someone can tell me what to do to fix this modem. Thanks
  • Anonymous May 11, 2010
    A power surge can be enough to cook a modem. I wouldn't recommend soldering anything. The lights may come on, but the could be the only part that still works. There isn't a fuse anywhere to replace. Does your phone pick up dial tone in the same jack? Or do you have the "stand-alone" dsl? (no dial tone)
  • 24 Answers
I'd say it's toast. When the power comes back on after an outage, it usually comes back on in a surge. It's not uncommon for electronics to be damaged when this happens. Check with your power company and see if they can replace the modem and the router for you.
Hope this helps!
Posted on Jan 31, 2008
6ya staff
SOURCE:
Power light is red modem will not work. Is it adapter or modem
yes ,this light is an indication that there is no power to the unit.
this need replacement
Jun 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Dsl light is red
if the dsl light is red, it means there is no signal coming thru your internet connection. so you need to contact AT&T to check your Dsl line signal
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
The modem I have 2wire it turns red where it says internet
Red means it can't get the DSL signal to get itself on the net. You might have DSL issues or the power adapter might be bad, this is a know problem. Mine went out twice. Check ebay for replacement adapter. Call about phone line.
Oct 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Cannot login to paypal and banks
Possible the power adapter is bad, know problem - check ebay.
Aug 15, 2009 | 2wire 2700HG-B Router (2700HGB)
2700HG Can't Sync to DSL Signal
The gateway is made by 2Wire contact them for repair.
Sep 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Lose DSL connection a lot!
Unplug you dsl and your router. Wait 20 seconds. Plug your modem back in. Wait until the DSL light turns green. Then turn your router on.
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
ATT 2wire 2701 HG-DSL lite on, but bad connection
If you have a 2wire HG2701 it experiences problems. You will need a new modem or a new router. I have one but it has the same problems. I went to FRYS Electronics and bought an speedstream modem. WORKS PERFECTLY
Feb 19, 2008 | 2wire 2700HG-B Router (2700HGB)
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Sep 16, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
677 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
