GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
About six months ago, my GE XL44 gas range (purchased Dec 2002) started showing signs that it's not maintaining the oven temp I set. I tried running the self-clean cycle, but that didn't change anything. When I want to bake something at say 400 degrees, I have to keep re-starting the oven (resetting the temp to 400 numerous times) while it loses 10 to 30 degrees every few minutes--this is of course without ever opening the door.
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Oct 03, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10843586
Points
101584
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
heatman101
2helpful
GE Xl44 does not reach or maintain setpoint . Display indicates increases of 5 degrees/second, but temp is not reached or maintained.
Have your oven ignitor checked. If they do not get hot enough quick enough the oven will light intermit. Usually when it does light you will often get a scent of gas or a poof. If that's the case, change the ignitor
6helpful
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
GE Spectra XL44 oes not heat to desired setting
The oven sensor ( WB21X5301) is suppose to tell the oven control when to turn on and off to reach and maintain oven temp, but before you go replacing it, try to observe how long it takes from the time you turn the oven on to the time the oven ignites. Ignition should be 30 seconds to about 90 seconds. If it is taking a very long time, replace the igniter (
WB2X9154
). Ignitors get weaker over time, and this should be looked at first, as both parts are not real cheap, so you don't want to just start throwing parts at it. Here is a trick you can try: On the JGBP90 (model you posted under) the broil ignitor is the same part number as the oven ignitor, so if the broiler, which is generally used much less than the oven, is working fine you can interchange the two ignitors to see if that solves your oven temp problem without having to buy a oven temp sensor first.
GE XL44 Spectra Gas Oven Range
Replace the electric ignitor, I did today... Temps are hotter than ever. $60 from an appliance suplier, easy to install.... Trust me
1helpful
2answers
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
