Question about Refrigerators
Kenmore side by side fridge
Both sides of unit is warm. There is a sound as if the compressor is coming on (for about 10 secs) and then a click. several times , but not back to back. there is some time between. I feel like it may be the overload/relay on the compressor
  • chrisgp Jan 29, 2008
    took off relay and it sounds like it has rocks in it, by shaking gently
  • 63 Answers
It sounds like your compressor is having trouble starting, and over heating. this could be one of the following
  1. start relay is bad
  2. run capacitor is bad
  3. compressor run/start winding burned out
Try unplugging the unit for a few hours to let the compressor cool down. Then plug it back in and see if the compressor starts. If it starts after it has cooled down, then it is likely out or low on refrigerant. If its low or out of refrigerant it will run until it over heats, then kick out on thermal overload. This is because there is not enough cold refrigerant being pulled back into the compressor to keep it cool.
Posted on Jan 28, 2008
  • Daniel Phillips
    Daniel Phillips Jan 29, 2008
    It sounds like you need new start components. I would first replace the relay you said that sounds like it has rocks in it. There is no reason it should sound like that.
  • 24 Answers
I agree with the above, but it may simply be that the compressor is faulty, and overheating even with enough freon, and thus locking up when it gets warm enough. The loud buzzing you hear is the relay trying to get the compressor to start, but most of the time it won't. When it doesn't run, the refrigerator and freezer, denied of the cooling the compressed freon supplies, warms up. Get your compressor or relays checked. Also make sure the coils are clean and free of obstructions so they can get rid of the heat they need to throw off.
Posted on Nov 08, 2009
My Kenmore side by side freezer and fridge sides are warming.
your ptc overload/relay on the compressors bad,unplug the unit and remove this ptc part off the compressor and replace it
May 02, 2012 | Kenmore Side by Side Refrigerator
Not staying cold
tell me do you hear a buzzing sound for about 5 sec ending with a click sound. every so often?? if so then you have a start device (relay) problem on the compressor you may think the unit is running b/c the lights are on and fan is on but if you hear that noise coming from the back of the unit while turned on then its the start relay or worse case the compressor is locked up..9-10 though usually its the start device
Mar 15, 2012 | Kenmore Side by Side Refrigerator
Motor egy90hlp into Whirlpool ed5fhgxkt04 start 10 sec, ang goes off 5min. come back another 10 sec. and do this cycle all day...also the compresor click on and click off sound, please helme...Alex..
HI,
From your description you have a starting problem with your compressor, this unit is called a relay. If the model number is correct, click on the relay link above and this is what your pat looks like that you need to replace.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 12, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge side works fine freezer side keeps running no matter were you set the temp -10 -20 degrees sounds like the fridge is running all the time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 06, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Fridge is getting warm & making a funny sound could it be compressor?
It could be the compressor or the start relay. If you hear a click sound, then your relay is good and your compressor is shot. If you do not hear a clicking sound, then your compressor is good and your relay is shot. Also check to make sure that under operation even if the compressor does not work the fan should still be spinning, even if it is warm air. Please rate
Jun 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Yesterday started hearing a buzzing sound from the fridge. Came home today with a pool of water in the kitchen coming from the fridge. Opened the freezer, ice is melted and inside is relatively warm....
I would check for a bad starter relay first unless you can verify that the sound is comming from the compressor. How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 16, 2009 | Frigidaire PLRS267ZAB Side by Side...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Mar 16, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore fridge not cold
You might have to have a repairman check the charge of freon in the system.
Nov 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
