Question about HP Inkjet 1200dn Printer
Hp 1200 business inkjet help
Hp 1200 business inkjet printer. all checks says heads and ink cart. full, 85%, but the yellow does not print, so put printer away for year, bring it back out and stll same , but now it says out of date carts. but the full a print fine except the yellow,, any help on the yellow cart, or just replace, dont know if its the print head or cart? and can i reset something that i will use the out of date carts !? or just chunk it and cry of the money wated on this thing, hp wants me to pay $ just so the can tell me the above... even when it was under warranty ,,, humm anyway thanks for any help
  • Anonymous Dec 29, 2008
    after every printout printer is giving cartraige allingment page printout
  • srdeetrobpl Dec 01, 2011
    my Hp business inkjet 1200 series is printing self test page from printer' panel, but not printing it if I give from my document or test print from printer menu. The color cartridge of cy and yellow and some time black blink please help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Posted on Nov 17, 2009
I had the yellow cartridge expire message awhile back. I looked at the cartridge & yup, it was expired although it was 1/2 full. I was not able to print anything, while this error was present. As a work around, I turned off the printer, set the computers date back 1 year, and turned the printer back on. Printed fine. After printer is working I was able to return the date to present.
This caused me problems with internet certificate issues so I gave in & bought a new cartridge. :(
Posted on Aug 03, 2008
HP 1200 Business Inkjet, dutifully prints BLANK info page from printer button.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 19, 2013 | HP Inkjet 1200dn Printer
I installed a new yellow ink cartridge and it still says that I need a new yellow ink cartridge. Have unpluggedprinter and reinstalled ink cart and still have problem.
Make sure that it is not a refurbished or aftermarket cartridge. These sometimes are dried out even though the ink is full. If you have separate print heads, check those too.
Mar 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Nov 16, 2009 | HP Inkjet 1200dn Printer
Yellow cartridge stopped workin halfway through a document although nearly full
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Cyan or yellow ink cartridge light stays on. Can not print.
I had this problem after I ran a print cartridge out of ink on my HP business inkjet 1200. The Print color light stayed on solid, and would not print.  After much frustration and trying many other things, I purged the air from the print cartridge pump, and that cleared the problem. To get rid of the air (which I could see through the translucent wall of the pump) I inserted a syringe needle (without the syringe) into the nozzle of the cartridge, and expelled some ink with the air. This is messy, so I recommend gloves. I have been refilling my cartridges for years.
Jan 30, 2009 | HP Inkjet 1200dn Printer
HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP Inkjet 1200dn Printer
Hp bsiness inkjet 1000 or 1100 actually theres a bunch just like that 2200...
Can you tell me exactly what is not printing right? If you could provide more detailed descriptions I can at least make some suggestions. How long does it work for after replacing the cartridge?
May 01, 2008 | HP Business Inkjet 1000 - Printer - colour...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP Inkjet 1200dn Printer Logo
2,095 people viewed this question
Ben Johnson
