Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
  • 2 more comments
  • IRMATOTIN Jan 28, 2008
    I can hear pump running but no draining of water, we checked the filter inside the dishwasher but not the actual hose that is connected next to garbage disposal. thanks for a quick response
  • Anonymous Feb 17, 2008
    water not draining in dishwasher and over flowing in the garbage disposal.
  • Cory
    Cory May 11, 2010
    Is the drainage tube blocked? Is the machine actually performing the drain? If there are no pump sounds / can't hear running water, there may be a problem with the pump.
  • Anonymous Mar 19, 2014
    what is the device to signal the dishwasher has drained?
My Frigidaire dishwasher would not drain yet I could hear the pump working. So I disconnected the power, hot water supply, drain line, and two screws attaching the washer to the cabinet. Pulled the unit out from under the cabinet and inspected the drain line. It was clogged pretty good with grease build-up. There was no water getting through. The grease clog was about 3 inches long and solid. I attached one end of the drain line to a faucet, used the clamp to keep it on the faucet, ran hot water through the line and the clog was forced out. I put it all back together again and it worked just fine.
Posted on Dec 20, 2008
  • 72 Answers
Have you checked the drain hose??? It may be clogged to some degree or where it meets either the garbage disposal or t-tailpiece, whichever you have, or where it comes out of the water pump. Also, the impeller inside the water pump might look good but may be worn, and check for broken glass which is hard to see in the bottom drain area at the grate. Hope this helps.
Posted on Jan 28, 2008
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Frigidare dishwasher wont drain, can hear pump motor start
Hi Mark, this is AP and I'm happy to assist you!
I understand you are having trouble with your dishwasher not draining and making odd noises. I would suggest checking the drain hose to ensure it has not become twisted or kinked. Even if the hose is not kinked make sure it has not fallen behind the dishwasher either as this can prevent draining. Additionally, you could check the filter at the bottom of the tub to make sure no debris has clogged the filter or disposal. Other than that the drain pump could be the culprit. If so, I would recommend a local authorized technician to come out and properly diagnose the dishwasher. I hope this information helps.
Mar 15, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
Dishwasher wont drain, it runs through the cycles but wont drain
do u hear the pump at end of cycles.try starting it right at end of cycle.u should hear water pump out
Nov 24, 2009 | Office Equipment & Supplies
Hi, I installed LG dishwasher, control board is working, water is coming from the water line but when hooked up to the dishwasher and dishwasher is on, there is no water coming into the dishwasher....
it should drain a bit of water out before it fills when it first starts. if that water doesn't drain out then you may have a drain pump fault. You can test this by dumping a few glasses of water into the machine then starting it up ( you should hear it drain that water out)
if that worked... then you have a fill solenoid fault or a line filter fault.You can check power to the fill solenoid or give it a couple of taps when its suppose to be filling to see if its just stuck. the inline filter could be plugged where you hook up the water supply to the machine (clean it or take it right out)
Aug 23, 2009 | LG Dishwashers
Wont drain
Pull out the bottom rack and make sure strainer is clear. If the outer strainer is clear remove the few screws around it to get to the other strainer to make sure it is also clear.
Dec 31, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher does not drain
My dishwasher will not drain. The water stays in the bottom of the dishwasher. When it should drain, I do not hear anything happening where I used to hear the pump working. Is my pump bad?
Jan 10, 2008 | GE 24 in. Profile PDW7880G Built-in...
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
167 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
