Question about Brown Stove Works Kitchen Ranges
Piolt on right oven wont get big enough to heat sensor
Five stare brown stove works model #TPM510-B SERIAL #3C4 3122
5 Suggested Answers
Sea Breeze
  • 4625 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
Posted on Feb 08, 2009
SOURCE: Simpson harmony nova oven ,
I had same problem. Replaced fan motor,really easy,but still would not turn. Got my brother inlaw to check it. Turns out it was the thermostat. He gave the connections a cleanup with sand paper, like you do car spark plugs. Works great,
Posted on Apr 21, 2009
  • 81 Answers
SOURCE: nedd a top oven element for brown stove 24"
since you're online, do an online search for the company and inquire about a replacement element for your model.
Posted on May 07, 2009
  • 585 Answers
SOURCE: I have an older model brown stove and cannot light the oven pilot
The oven pilot is accessible through the broiler door, (you're pretty much laying on the floor to light it) or through the oven bu removing the oven bottom panel. To remove the oven bottom, place fingers in holes near the door, and apply pressure to slide the bottom toward the rear, and lift when the front (by your fingers) comes free. Remove completely and set aside. You should now see a flame spreader (V-shaped metal pan) retained by one or two winged screws. Removing the screws allows removal of the spreader. This exposes the burner, complete with pilot. There is two tubing lines to the pilot assembly, one about 1/4 inch dia. and one much smaller. the one at the end of the 1/4 inch tube is the pilot. The piece at the end of the really thin tube is the thermocouple. You have to heat the thermocouple to get the gas to come on to the pilot. A match just won't do it as you need to apply a flame to the thermocouple for about 30 seconds or so. Heat the thermocouple until the pilot will self-sustain. When the pilot stays on on it's own, put it all back together. If you elect to just go through the broiler, again heat the thermocouple until the pilot will self-sustian.
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Posted on Oct 21, 2010
0 characters
1 Points
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Brown gas range auto ignition not working
If the problem is with all the burners then the igniter module may be defective. If this is happening only with some burners then the cable to the ignition point has become loose or is shorting with the body.
I am assuming the model number is correct but I am not finding any details for this 24 inch freestanding gas range. If the oven is electric and if it is running that means at least the electric power is reaching the unit.
Brown Stove Works INC
The oven parts are available here
Brown Range Stove Oven Parts
Sep 03, 2014 | Brown Stove Works TM110-3 Gas Kitchen...
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
I have a black Maytag Gas Range stove the oven wont heat up. The ignition what i think it is, is glowing but when I tap the bottom of the stove it will light. What part do I need and where can I get it....
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Aug 31, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
GE JBP90 Gas Range is not holding heat very well in the oven. Takes ages to heat up to cook a pizza. When oven is on, heat pours out from under the control panel. I suspect mice have messed up the...
Your posted model is for an electric stove. Your question pertains to a gas stove. 2 things to look for: The most common of which is a weak ignitor. The second most common being a faulty sensor. Since you made no mention of a fault code I am going to assume the problem is the ignitor. For ignition to occur the gas safety valve has to release the gas to the burner. In order to do it the resistance on the ignitor must change. Over time the ignitor gets weak. One way to tell is by looking at it. It should be so bright you cannot stare at it very long. If it appears to be a dim orange AND you can bump the stove and sometimes get ignition then replace that ignitor.
Aug 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven Ignation would not Stop flickering after ignation
This is usually due to the "brain" of the stove going bad, better known as the control module... not an expensive fix if you can find the part and due it yourself... you can locate it iether in the back right corner when you lift the stove top or it's under an access panel below your broiler drawer depending on model.
Jan 15, 2008 | Brown Stove Works TM110-3 Gas Kitchen...
Lower heating is not working
Replace the igniter even if it "appears" to be working. Bright red isnt hot enough. It has to be bright white. Goodluck...
Dec 17, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
16 people viewed this question
Top Brown Stove Works Kitchen Ranges Experts
Dan Webster
Dan Webster
Are you a Brown Stove Works Kitchen Range Expert? Answer questions, earn points and help others
