Question about Toshiba Satellite M35X-S111 Notebook
Power consumption/in watts
Sony vaio VGN -NR17G power consumption in Watts
  • rajuittyerah Jan 29, 2008
    VGN-NR17G is a SONY product.
    Thanking you,
    Raju.
    Problem Solver:
  • 3 Answers
May I try this?
Power consumption of laptop is calculated by:
connect a MULTIMETER on AMPS in series with the AC line for LAPTOP,
and read the AC-miliamps as they display.
If the battery is charging, the reading may be higher, if you running
heavy-buzzy software, the AC-Miliamps reading is slight higher.
Convert AC reading (use a calculator) to DC for your understanding at "WATTS" consumption
as it feed from the line.
Check the factory specs, and battery charger rates, high and low. (low at end of cycle).
Max rate can be obtained by discharging battery to 10% or less.
Posted on Nov 22, 2008
    Problem Solver:
  • 20 Answers
Most likely 350 or there abouts.
I tried to look up the specs but VGN -NR17G is not a known model number.
Posted on Jan 28, 2008
6ya staff
SOURCE:
How many watts power adapter I need it ??
Best to look on ebay using your laptop model and add the terms genuine / original. Using cheap chargers may damage your laptop.
Higher wattage will charge your battery quicker.
Jun 30, 2014 | Sony VAIO VGN-N365E/B Notebook
Tip
Power Consumption by CRT monitors
<span>Frequent PC users especially desktop PC's with CRT monitors has to be very careful in using the CRT monitors as that consumes more power than other types of monitors in market.</SPAN><br> <span>Recent research has found the CRT monitors to be consuming 60-80 watts of power for a normal 15 inch monitor compared to 25-35 watts for LCD. The power consumption is almost double in CRT's. If you consider 17-19 inch monitor the power consumption in CRT's might go up to 100-150 watts roughly.</SPAN><br> <span>It is advisable for more than 1 CRT monitor users to keep the monitors switched off when not in use so the power consumption is reduced.</SPAN><br>
on Dec 12, 2010 | Computers & Internet
I want to know how many watts are needed to run a Samsung ML 1665.
you can get this information form the box of your printer.... it must be there at any side of the printer box......
Power Consumption, 250 Watts. Standby Power Consumption, 10 Watts
Jun 22, 2011 | Samsung ML1740 Laser Printer
What is the average power consumption (watts)? What is the start-up power consumption?
Sir / madam
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 and 750 watts. Horsepower was originally defined to compare the output of steam engines with the power of a draft horses... In refrigerator the unit use is horsepower(HP) 1 HP = 750 watts
Jun 21, 2011 | Refrigerators
I need to connect my vaio(vgn-nr17g) to a projector,but i can't find the drivers for it!!
When I connect a computer to a projector no additional drivers are needed. Just connect the VGA or DVI port to the projector. The projector may be the limiting factor, though, as far as detecting the signal from the VGA cable, and you may have to follow the instructions of the projector to make it work correctly as far as when to power up the computer and what not.
Good luck on this.
Feb 04, 2011 | Sony VAIO VGN-FE880E/H Notebook
What is the power consumption for HP laserjet 2430dtn
hello welcome to fixya
The details of power consumption for HP lase rjet 2430dtn are:-
If 'll be Active then : 625 watts
If it 'll be on Standby then : 11 watts
Power save: 8.5 watts
I hope it 'll helpful for u,
Kindly Do Rate if it is Helpful
Thanks & keep using fixya
Feb 19, 2010 | HP LaserJet 2430dtn Printer
Hi dear ,i was having in my sony vaio model:vgn-nr17g windows vista program & when i replaced it with xp the function of brightness control of the monitor is not working so kindly help me to solve it.
Did you install .NET and next Quick Launch driver?If not install them,or if you installed QL without .NET first uninstall it and then install in that order.
Jun 25, 2009 | Computers & Internet
I need an windows xp drivers for sony vaio vgn-nr17g
look at sony's website and look for drivers there. can you post your hardware specs?
Jun 09, 2009 | Microsoft Computers & Internet
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Toshiba Satellite M35X-S111 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
