Check your connections. If you put the component wires in wrong it will confuse the system. Once I had the red in correctly but because of poor lighting, had switched the green and blue around into their wrong inputs. My result was a black and white picture. Not saying that this is your problem but look at this first. Also, using regular composite wires (red white and yellow) and using them on the component inputs may have the same results
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
There are may possibilities, but these are some of the basic things to check.
Could someone have turned the color down?
You can go to the setup menu and "Reset" the player to the factory settings.
Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
Are the cables in good condition?
No breaks, loose connectors, they weren't smashed under a piece of furniture?
Have you tried a different set of cables?
Does the same thing happen?
Did you "Reset" the DVD player?
Maybe the DVD player is bad?
Does it work OK, or is it black and white too?
Maybe the connectors on the TV are bad?
Is there a custom setting on the TV for that connection?
On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
Best wishes,
-Greg-
SOURCE: my dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
