Question about Brother IntelliFAX 2800 Laser Fax
Cover open
Dear sir
I habe brother 770 fax machine. it was working fine untill last week.but now I try to send fax and get massage that TOP COVER OPEN ? so what I have to do to solve this problem.
  • naren_shah69 Jan 28, 2008
    how can I fic problem.
    Scholar:
  • 78 Answers
The control panel opens to give you access to the scan glass and orginal feed rollers. There are clips either side which keep the cover down with time they can become weak and not hold down the cover correctly. While the control panel cover (top cover) is open carefully bend the clips outwards a little for more pressure. Also these type of machine can also read cover open messages when there is a jam inside. Check for jams including in the drum unit.
Posted on Jan 28, 2008
I have a brother 770 fax. When making copies or sending faxes the paper has long black narrow lines running from the top to bottom. Please help.
Hi There!
One reason why you're having a black line on the copies you make and faxes that you send it's because the scanner glass inside the fax machine is dirty. Here's what you can do to resolve you're issue.
-Make sure the printer is off and unplugged from the power outlet for your safety. -Open the control panel, Prepare a dry lint free cloth and isopropyl alcohol, dampen the cloth with a small amount of alcohol. -Inside the fax machine look for a the long scanner glass clean it with the dampened cloth, using hand try to feel if there are debris or dirt and concentrate on cleaning that part. -Directly above the glass you will see a white strip clean that also with the dampened cloth
Once you're done cleaning, close the cover and plug it back in. Try to copy a blank sheet of paper and if you can still see the same line clean it again for about 3-5 times, Make sure to make a copy everytime you clean the glass.
Hope this helps!
May 08, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
When I send a fax, the recipients report a black band appears covering 3/4" in one margin
Open the front cover and clean the scanner glass - there must be some alien substance like dried up correction fluid or ink on it that causing lines to appear on the recieving side.
Oct 02, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Where is the top cover switch? I can't find it.
This is the manufacter's official manual link:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_750_770_EN_85.PDF
On page 63 it shows you how to open the top cover. You must open the front cover first then open the top cover by pressing the blue levers on both sides of the top cover.
It also has a diagram.
Hope this helps!
WizardRepair
Jul 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Can't send faxes , keeps saying document jamed
Open the front cover by pulling it towards you (that is the cover where are the digits and other function keys), see if any paper has inside and than close the front cover and press the " Stop " button.
Remember if you do not close the front cover good the message will still appear on the screen because the machine thinks that the cover is not closed. That happen because of the sensor on the front cover which detects do the front cover is closed so check dose the door is good closed. If your machine do not pull the documents in the " document feeder " than open the front cover and you will see pair of rubbers inside, clean them with alcohol or glass cleaner and clean peace of cloth.
Jul 03, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Print unable 50
The carrier that goes back & forth has a timing strip ( a plastic strp about 1/4" wide and goes the legth of the machine) If you open the top cover. put your hand in the hole fill twards the front of the machine and the top cover. now the carrier has a U shaped sensore that this strip goes through. 9 times out of 10 the stip has gottin bummped out of position. now you need to put that strip back in the sensore. hard to do with covers on. if look close at the top cover not that hard to take off.
good luck
Jan 07, 2009 | Brother Fax-1360 Plain Paper Inkjet Fax
Brother intellifax 770 plain paper
The tab is probably broken that trips the top cover switch. Try sticking a small piece of paper down where the tab used to go.
Jul 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Message change catridge in the display
this is just asking if you changed the cartridge or not, if you did press either enter/copy(usualy green button) if you didnt change it then either cancel or red button Hope this helps Cops
Oct 04, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother IntelliFAX 2800 Laser Fax Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
