Question about GoVideo Go Video Progressive Scan DVD Recorder w/ BuiltIn TV Tuner
What DVD+R Do my player require?
I can't find the right (DVD+R) to record with my unit. I use to use a TDK DVD+R brand but it nolonger works. My unit will not format, the recordable disck that I use. I have bought almost every brand of recordable DVD+R Disc. The brand I use to use was the TDK DVD+R 4.7 Single Side (RW), but that same brand is nolonger.
    Problem Solver:
  • 5 Answers
The disks required by the go-video are the dvd+r only..the brand shouldn't make any difference.
I would stay away from the 'cheapies',but you dont need expensive disks.
if you get an error when you start 'rec' ,the message displays why.
check your settings,and be sure the record timer is off.
if you have multiple segments recorded,and you record until the disk is full,
it may not finalize because there is not enough room on the disk for the menu structure.
the disk will only play in this machine. if it simply wont record,you might try a lens cleaning disk.
or you have a failure in the write laser.
Posted on Sep 23, 2008
When I insert a blank DVD+R to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
some discs don't work in some recorders. I always use verbatim, ritek or tdk discs and have very few problems. if the recorder suddenly dislikes a batch of one brand, I'll use one of the others.
Jan 29, 2015 | GoVideo VR3930 DVD Player/VCR
Some new dvds record right through, others from the packet come to 'NO RECORDING POSSIBLE' at some stage - is this to be expected?
I've occasionally found that some brand new DVD-Rs are rejected by Pana recorders, and have put this down to manufacturing faults on the discs. It's usually not worth taking them back when one disc of a pack of 100 is faulty.
All I can recommend is that you use a renowned brand, such as TDK, Maxell, etc to reduce fail rates.
May 27, 2013 | Panasonic Diga DMR-EH75V DVD...
What brand of DVD do I use to record
Any brand name DVD disc like TDK,Memorex or RCA extra..as long it is 8X or 16X DVD+R format for one time recording only.Or DVD+RW u will able to Re record over the old data's was in the DVD disc earlier only.
Aug 31, 2011 | RCA DRC8335
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Can't find a dvd that will work in EWR20V4
Go to Office Depot buy TDK brand 16x DVD's thay are the only one's other than the Sony 8x that my machine can use. the Sony 8x which are getting harder and harder to find work great. Just go to O/D and buy a small pack of 25 or 50 of the TDK -R 16x DVD's and test them on your machine.
good luck
Aug 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Trouble with DVD+RW Disks being compatiable or staying formatted
cos they are cheap - get some decent branded discs such as TDK or tayo yuden and it should be fine
Also check the manual and or requirements on there website and it should show which are the best discs to use for that player but TDK or tayo yuden should be fine.
www.svp.co.uk or any where you can buy discs from should be fine
Apr 15, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD recorder wont record
The instruction manual says it strongly recommends for good quality recording : Sony Maxell and TDK and has been been tested for Verbaitim as well.
Nov 11, 2008 | Funai TruTech DVDVCR Dual Recorder
Firmware update
Sorry to hear about your problem. I do own this model too. I have not gotten the update myself. I just started using the dvd recorder.I bought a pack of dvds (Ativa) and now I need to return them, they are not supported by this dvd player. I called the 800 number and they told me some of the dvd brands it supports: JVC, TDK, Memorex, Maxell and Sony. I know Sony works, because I used them before. I also read "Vibratim" brand from Sam's Club works.
Nov 26, 2007 | Sylvania DVR90VE DVD Recorder/VCR
GoVideo Go Video Progressive Scan DVD Recorder w/ BuiltIn TV Tuner Logo
59 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
