Question about Compaq Presario 2110US (DB382AABA) PC Notebook
Compaq presario 2110 us
I have a black screen that says files or system windows 32 missing. Can I repair it without a cd rom. I don't have one.
  • mtnroad Jan 28, 2008
    Thanks.
    Thanks.
    Champion:
  • 217 Answers
Unfortunately no. The files needed are on the windows cd.
Posted on Jan 28, 2008
Compaq presario c300
Switch the computer off - remove the battery if necessary and wait a couple of minutes. Replace and try restarting.
Jul 28, 2014 | Compaq Computers & Internet
Hi!! I have a Compaq Presario that a friend gave me a while back that used to work and start up..but it doesn't now and I haven't been on it in months. It keeps saying that: Windows could not
The "Win32 config" system folder and the files within it are crucial to the Windows Operating System's stability. If any of these files become damaged or corrupted, you likely receive error messages. Fortunately, Microsoft puts the files to repair these problems on the installation CD that comes with your operating system. The original install disk offers a quick way to repair the system. Damaged files are replaced in only a few minutes.
Insert your Windows CD into the computer drive. Restart your computer. On startup, look for the message, "Press any key to boot from CD" and press "Enter" on your keyboard. You should see the blue "Welcome to Setup" screen. Click "Enter" on the "Welcome to Setup" screen. Read the "Microsoft Software License Terms," then press "F8." Use your arrow keys, go down and select the Windows installation you want to repair. Press "R" for "Repair." Windows will now start to restore the Win32 System to your computer.
Feb 02, 2013 | Compaq Presario V4000 Notebook
I have a laptop that is a Compaq Presario and upon start up it says the following a kernel file is missing from the disk Insert a system diskette and restart the system how do I fix this
Which kernel file are you missing?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following commands and press enter after each one:
sfc /scannow
chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 04, 2012 | Compaq Computers & Internet
Compaq presario cq56 flashes from red start screen to cursor back and forth and cant open f11
Sounds like your boot files or system files has either a corrupt file or missing file.
You will need a repair disk or system disk to remedy this. Put the disk in the cd drive and boot from it. You wan to get to a dos prompt (black screen with white lettering) and run the Check Disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 01, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Copaq presario v 2000 crash
HI
Can you log into windows normally?
If not, you may need to install windows from the beggining.
In case that windows work fine & the problem is just with system files, you can follow these steps:
1- From Start Menu choose "Run"
2- Type: SFC /SCANNOW
3- Press Enter & insert the windows XP cd when asked, then click continue or restart as the window tells you.
This should help you repair almost every problem in th systm folder.
Hope it works.
Nov 05, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 12, 2008 | Compaq Presario 1700 Notebook
Have gone to black!
The error: Window could not start because the following file is missing or corrupt;
WINDOWS\SYSEM32\config\system
You can attempt to repair this file by loading the Win CD into your cdrom drive. Start the PC & press the F5 key every 2 seconds & windows boot menue will load.
Choose the cdrom drive that has the Windows CD in.
Select "r" at the first screen to start repair.
Once back in windows run a full system virus scan.
Good luck & have a great day!
Mar 14, 2008 | Computers & Internet
When switching on my laptop ( Compaq presario C300 ) I get a message on the screen which says - Windows could not start because the following file is missing or corrupt:...
Yaa, Your OS has been currepted, you have to re-install it. There are two option to do this.
1. If the system is displaying the file name which has been missed or currepted, then you can repair it.. to do so
a. insert your setup CD and make boot and at first screen press 'r' it will display the drive name where your windows has been installes.
b. type the number which is appearing before your drive later and press enter key.
c. type your administrator passward and press enter agian.
d. now you have logged in to your windows setup folder.
e. using CD command goto the location of file which has been currepted and copy that file from your setup CD.
f. It may ask you for overwrite, if so, then choose 'y' for yes.
Now reboot your system it will be start..
In another way just reinstall your setup, i,e, press enter key instead of 'r'
and follow instructions given on the screen.
Thanks
Iqbal
Mar 08, 2008 | Computers & Internet
System file is "missing or corrupt"
You MUST use the installation bootup disk to install windows it is the only way........... NOT THE RECOVERY DISK this is a MUST. Allow it to go through the motion of installing Windows until it cannot go any further. Then press the "R" key for the console. When in the DOS screen TYPE ... chkdsk /p Windows will repair itself and then you will recover all your data it should be back to normal.
Sep 24, 2007 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 2110US (DB382AABA) PC Notebook Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
