Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I've been having problems trying to install 1tb FreeAgent External Hardrive on Macbook Pro. I've had the same problem before with another product from Seagate which I fixed so I can use it on the Mac so I know that it is possible to do it again. This product was designed for Windows XP.
  • usacrissy Dec 29, 2009
    Thank you I tried that already the program began to erase the format and then stopped saying that there was an error. I think that the best way was to take back the hard drive and get a new one that is compatible with the mac. That is logic in a nutshell that I did not have at first and then learned the hard way...but thank you so much for trying to help.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,099 Answers
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Posted on Dec 28, 2009
SOURCE:
How to format my new seagate freeagent 500 gb with macbook?
Here is a link to Seagate that describes how to fromat your drive fro a Mac. GOOD LUCK!
Oct 14, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 1TB Ext HDD wont power up.
try with removing and reconnecting the bus cable and smps cable.
and try with different bus connection
Jul 13, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Drive Buzzing and Wont work (Seagate External Freeagent 1TB)
You are in trouble!
The buzzing sound is the heads trying to realign themselves at the beginning of the platter.
You could try putting it on a side and hope gravity helps.
But i'm afraid its broke beyond repair.
May 13, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Mar 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My macbook pro does not recognized freeagent 1 TB. It sucks!!!!
You could contact Freeagent technical support at their website.
Jan 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Read only drive
Fixed it by partitioning the Drive and formatting the Partition to Mac
Mar 01, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate freeagent external harddrive
In any Mac OS System/Computer It cannot and will not write files to a NTFS Drive, but it will read.  The easiest solution for this is to search google for a program called "macfuse" this should fix the problem :)
Jan 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
405 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
