Question about Olevia Kolin DLT2711M 27 in. LCD Television
Kolin color tv,degausing problem.
The tv have tinted screen,vertical red color on left side,spot of green on rigth side.i used demagnetizer but didnt work.i change the degausing circuit but didnt clear the screen.what another technic to solve this trouble.please help me.thank you.
  • angelsweet08 Feb 05, 2008
    KOLIN color tv #kcp-2190a(KALEA) not olevia kolin,it uses cathode ray tube. degausing has red vertical color at left side and spot of green color at right side of screen.sorry i forgot the model when i posted this problem.Macmante thanks for helping,hope you post a solution on this model.i chaged the degausing ckt. and try a demagnetizer but useless.
  • Anonymous Jul 08, 2008
    my kolin tv keeps coming to a red color
Check first the CRT-Socket then the K-5 to the Chroma. if not work it then the final is CHANGE The Video chroma
Posted on Nov 13, 2008
  • 314 Answers
Degaussing coils do not work on LCD or Plasma TVs, Cathode Ray Tubes only. There should be no (not any type) demagnetizing circuitry on that type of set, so I have no idea what you replaced/adjusted. I believe one of two things to be the problem. Either the LCD screen itself is bad (possibly it has been struck with something and that has broken electrical connections that cannot be repaired) so replacing the LCD panel may prove to the the fix. However, the circuitry that drives the LCD panel could be at fault, improperly driving an otherwise good LCD screen. That is a tough call. I would carefully inspect the screen up close looking for tiny cracks in the glass. This could be a pricey repair either way. Good luck on that one. Perhaps you should include some more history of the set. Did it fall or get knocked over, was recently moved, got wet... anything would be helpful. I know that children of a certain age are known to go up to a set and slap the screen. A friend has a rear projection Pioneer with that type of damage.
Posted on Jan 28, 2008
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Red tinted picture
Try reseting the TV first by unpluging all the cords for 4hrs and then plug it back.
I will be posting more troubleshooting steps..
Apr 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
I was told my samsung HCN4727W needs to be demagnetizing due to it drooping at the top.How would I go about doing it thanks
Not,possible to dequassing,to demagnetizing,if u drop the tv,because the CRT yoke is damage the magnetic field out of wack,can not,do anything to it.
Jan 12, 2010 | Samsung HCN4727W 47" Rear Projection...
Problem with picture color
Magnetized The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 26, 2009 | RCA F27TF720 27" TV
Two color variant spots in the middle of my Sony KV-34HS420 34 in
your tv needs to be degaused or cant be a bad picture tube unless it was dropped.
you can call a local shop to degause it in your home.rather easy and inexpensive to fix.
Sep 24, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The lower left 1/4 of my screen is discolored slightly. It shows red highlights in peoples faces. The area is shaped a a square or rectangle and seems to be exactly a quarter of the screen. The TV was...
it need to demagnetize using a demagnetizer or permanent magnet (PM). move the PM to the center of the tv then rotate it ccw make a round small circle to bigger circle as you move the PM away from the screen. But do not put speaker near the tv. You can also switch off the tv for a night then turn on again this process will demanetize the screen automatically but be sure no speaker put near the tv. If this will not solve the problem. it might be the technician forgot to refix the degausing coil or Thermostat.
Jun 25, 2009 | Televison & Video
Left side of sony 43'' flat screen has red tint
This issue occured under magnatic field it will remove automatically after some time.
the second option is, you call a Repairman and told him to degauss
the screen after degausing the screen your issue will be fixed.
Nov 23, 2008 | Sony KV-36FS16 36" TV
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Olevia Kolin DLT2711M 27 in. LCD Television Logo
289 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
