Question about Canon PIXMA MP160 All-In-One InkJet Printer
Hi! what are error code 2,114,0 ?
  • 4 Answers
See manual pg 87
e2- reload paper, press black or color key on printer
114????
0????
Posted on Feb 02, 2008
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
Oct 13, 2012 | Frigidaire FSC23F7DSB Stainless Steel Side...
COD ERROR 2,114
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
116-325 error code on docucolor 3535
Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
Sep 22, 2010 | Xerox DocuColor 3535 Copier
Hi any idea what causes this Brivis error. err
go to the brivis web page and type in serial number and error code theywill give you a code and repair instructions.adrian,,,,
Jun 29, 2010 | Heating & Cooling
To solve code error 0146 and 0148
Hi there.
0146 error is DST Log contains previous error(s).
0148 error is
IDE ERROR: status (x) (s)
This could be a problem with the BIOS, restart the PC and hit F2 as it starts up, this will take you into the bios, reset the bios to default setting, press F10, save and exit the bios, the PC will restart so perform another check and see if the same error code return.
Good luck
May 29, 2009 | Dell Inspiron 6400 Notebook
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
232 people viewed this question
old marine
old marine
