Question about Maytag MAT12CS Top Load Washer
Machine not starting
i have just moved to a new place, where its furnished with MAT12CS top load coin-operated washing machine.I inserted the coins, but its not accepting the coins.. Not any activity i coudl find from the machine.
Also i find no indicator lamps are glowing. Let me know what could be the problem.
Best regards
Sri
  • Anonymous Mar 25, 2014
    I got a coin in the washing machine pump, want to know how to access.
  • 770 Answers
These machines are owned by a company or your Landlord you will need to contact them for the repair on the Coin slide
Posted on Jan 28, 2008
How to change digital amount on older maytag topload drop coinop
open service door,move switch and display will read 6-- (6 and the # of coins set for) use the buttons top and bottom to go up or down to desired amount
Feb 26, 2013 | Maytag MAT12CS Top Load Washer
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
Just bought brand new commercial coin operated washing machine top load...everything is level tried washing a load and at the spin cycle the machine vibrates so bad it seems like it's going to take off. ...
maybe when you were moving it, one or more of the springs that keep the drum centered came off,unhook everything,drain it,tip it over face down on a piece of clean carpet, make sure everything is in order,all supports are in place, 2 people to tip it
Jan 31, 2010 | Whirlpool CAM2752RQ Coin Operated...
I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Sep 27, 2009 | Washing Machines
By pass coin mech for a maytag washer mah21pddww
All you have to do is program the machine to run with no coins Open the service hatch and use the woolens key to scroll through to the setting which is your multiplier setting it may be set to 610 for example you need to set it to 600. While viewing this number use the permanent press keypad to change this setting each press changes it by one increment keep pressing it until it goes back around to 600 Then close your service hatch and the machine will be set to work for free you only have to select which program you want to start.
Hope this Helps
May 13, 2009 | Maytag MAT12CS Top Load Washer
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Water supply
look on the control board. there's some DIP switches. these are set according to the number of coins needed to run the machine. the coin acceptor reads the number of coins going through it and advances the control board one increment for each "good" coin. objectionable coins are rejected.
Sep 06, 2007 | Maytag MAT12CS Top Load Washer
Empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Maytag MAT12CS Top Load Washer Logo
250 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
