Question about Bose 151SE Main / Stereo Speaker
Subwoofer connection Carver Surround 5.1 speaker set-up with Harman Kardon AVR 147 receiver has single RCA-type subwoofer output. Subwoofer has dual-right/left RCA input and output connections OR speaker terminals. HK suggested using a Y connector for RCA connection Any issues with this set-up? Thanks
  • Anonymous Feb 11, 2008
  • Anonymous Mar 31, 2014
    Do you have a solution for us ?
    Problem Solver:
  • 6 Answers
Actually, A common practice in the audio world is to send a MONO signal from the receiver to the subwoofer. The LEFT (WHITE) input on the subwoofer will bridge the connection producing optimal performance for your subwoofer. try this connection -- 1 RCA cable from the output of the receiver to the LEFT (WHITE) input of the SUB. Turn on the LFE (Low Frequency Effect) switch on the subwoofer and make sure the Phase setting is (IN PHASE 0 degrees).
Posted on Feb 17, 2009
  • 145 Answers
If this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Posted on Jan 29, 2008
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Jun 06, 2010 | Boston Acoustics PV800 Subwoofer
My receiver doesn't have a dedicated subwoofer output, can I still hook up a subwoofer? I have a harmon kardon avr 25
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
May 29, 2010 | Harman Kardon AVR 25 MKII
My JVC Subwoofer does'nt work !!! Connected
If your connected via the sub pre out on your reciever check your setting to make sure that it is turned on also if this is done you may try using speaker cables to by wire the subwoofer
May 24, 2010 | Harman Kardon AVR 2550 Receiver
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Feb 27, 2009 | Bose 151SE Main / Stereo Speaker
How do i connect my subwoofer to my tv
Have you tried connecting an AV cable from yoursuboofer to your TV?
If so, what type of connection cable does your Woofer have?
Is your subwoofer apart of a surround sound system or is a separate unit?
Feb 10, 2009 | Harman Kardon AVR 300 Receiver
Harmon Kardon receiver not compatable connection to subwoofer.
Most subwoofers with RCA type connections are powered subs. They are commonly sold in most hi-fi stores.
Unless your subwoofer has a separate mains lead it will be the wrong type I think.
Dec 07, 2017 | Harman Kardon HKSUB 12 Subwoofer
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
No surround sound when playing a dvd
put it on dolby and make sure all the speaker outlines light up. I can't get a subwoofer to work, these things are lemons, had it 7 yrs now, and never has worked entirely as it should. I'm looking to replace it now.
Apr 12, 2007 | Harman Kardon AVR 320 Receiver
Bose 151SE Main / Stereo Speaker Logo
640 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
