Question about Edirol UA20 USB Audio/MIDI Interface 24/44.1kHz Sound Card
Can figure out how to install Antenna
Do you know where I can get installation instructions for this product?
Same here i've lost my installer disc so how do i work it?
please help!
Posted on Feb 18, 2008
    Champion:
  • 217 Answers
This information may help:
http://www.zzounds.com/item--EDIUA4FX
Posted on Jan 28, 2008
Not using cable anymore. bought an antenna. how do I install. did get directions but did not work
Hello, Patr -
This article and video may prove instructive:
https://www.digitaltrends.com/home-theater/how-to-buy-and-install-an-hd-antenna/
There are a variety of over-the-air (OTA) TV antennae. Without knowing exactly what antenna (make and model) you purchased, it is a challenge to provide you with specific directions.
You can add more information on your antenna by choosing Comment and typing the information in the Comment box.
Best wishes.
May 25, 2018 | Televison & Video
I need installation instructions
Installing a CB is rather easy. The power needed is minimal since output power is limited to ~4W this means at most 10W of power from the battery is needed. This is less than 1 Amp for a 12 Volt system. You can use the car's regular power port for this. (Used to be called the cigar lighter when a heating element was supplied in the car.)
The antenna on the other hand is more problematic. You can either install something or use a mag mount antenna. The Mag mounted antenna will be easy and should do until you decide where and what kind of antenna to install permanently if that is wanted.
The best location for an antenna is up high in the middle of the car top. This is not always practical. the best antenna is a full quarter wavelength vertical, that's about 9 feet long, and we don't see too many of those any more but they are available.
I recommend you buy a fiberglass shortened mag mount antenna to play with to see if it is good enough for your use. If not you know that a quarter wave antenna is needed and then you need to decide to either mount it to a rear bumper (mostly for a car mounting) or to a strong side mirror, trucks usually have those.
Hope that helps.
Apr 10, 2016 | Radio Communications
HP Photosmart 3210 service & repair manual sought
There is NO technical information available for any HP inkjet models, not for anybody, even service centers.. HP offers exchange only.
Apr 02, 2014 | HP Photosmart 3210 All-in-One Printer...
How do you replace the atenna mast for 2005 sierra.
How do I install a new antenna on my GMC 05 2500 Sierra. I have to replace the base because it broke off. I've taken the dash off. But cannot seem to fish wire through the firewall.
Nov 26, 2010 | 2005 GMC Sierra
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
I don't know how to use a scanner....LOL I mean, I have one, but I have never figured out how to actually "scan" anything in...LOL
PLace the document to scan facing down onto the canning glass. Open the scanning application installed on your computer (If you dont have the apploication, install it with the CD that you would have recieved with the product). Then follow the instructions and then save the scanned document as desired.
Apr 09, 2010 | HP PSC 1510 All-In-One InkJet Printer
I want to install internal antenna in samsung
test test 18:30rfv
test test test 18:31s rthsr thsty
Jun 27, 2009 | Cell Phones
How to install an amplified indoor HDTV flat antenna? Have not purchased the product yet but I am very interested in purchasing it.How do you install it? Please note I have a LCD Flat Screen TV made by...
The antenna, will more than likely, come with a feed cable with a screw type F connector that you attach to the antenna connector on your Phillips TV. Pretty simple! Most antenna's will come with complete installation instructions.
Jun 27, 2009 | Televison & Video
2007 Hyundai Santa Fe Limited
Hey all,
I was able to get installation instructions for the cross bars from http://www.capitolhyundai.com and from http://dealerfit.com.  Thanks much to these folks for providing a pdf of these instructions free of charge!
Below is the text from the instruction set that worked best for me.  The other instruction set was nearly identical but it had an alternate Step 2 which involved using a small plastic pry bar.  I added that alternate Step below in the instruction step.  Hopefully I'm able to insert the image of each instruction set so that the Figures are visible.  Its actually not that easy getting the rear rail covers off and its pretty easy to crack them.  I'd recommend gently rocking the covers for a couple minutes in order to loosen them up.  Once you get the covers off, the rest of the install is a breeze and can be done in 2 minutes.  If you have questions, go ahead and contact me.  I also took several photos of my install and that might be helpul.  Cheers!
-LePig
SANTA FE 2008 PIN U8210-28000 Cross Bar Assembly Installation Procedures
Kit Contents: • (2) Cross Bar Assemblies Required Tools: • Flat Head Screwdriver
INSTALLATION INSTRUCTIONS
1. Carefully unscrew and remove radio antenna. 2. Grasp the rear rail covers with both hands. Squeeze and pull up & inwards (toward the center of the vehicle) to remove covers. Take care not to break off the tabs by lifting the rear section of the cover first (Figure 1). Be careful not to scratch, damage or dent any painted surfaces. DO NOT PRY AGAINST THE VEHICLE BODY, THIS CAN CAUSE DAMAGE TO THE VEHICLE. 2. - Alternate Method - Locate notch in rear of each cover to insert plastic pry bar.  Remove cover by prying up (with tool) and lifting rear at 45 degree angle (Fig 1). Be careful not to scratch, damage or dent any painted surfaces. DO NOT PRY AGAINST THE VEHICLE BODY, THIS CAN CAUSE DAMAGE TO THE VEHICLE. 3. Check assembly clips for damage and dislocation. Replace if necessary. 4. Open the lever on one side of front/rear cross bar. Gently set the cross bar, with the arrows facing forward, into the channel of the side rails (Figure 2). Guide both sides into the track. 5. To adjust cross bars, open lever and place cross bars in desired location. Close lever (Figure 3). Try to move bars forward/back until they lock into place. 6. Reinstall rear covers by holding cover at a 45 degree angle and inserting the front tab into the rear of the roof rack. After aligning, snap cover in place (Figure 4). Be sure that the rubber lip does not interfere with the covers, and that the covers are fully seated. 7. Reinstall the radio antenna. Note: To remove the cross bars, remove the antenna, remove the covers, open lever of cross bar and slide to end of rail. Hold down locking fingers (on both RH/LH rear rail supports) with a flat head screwdriver (Figure 5). This will allow removal of cross bars from the rails.
Jul 02, 2008 | 2007 Hyundai Santa Fe Limited
Replacement Antenna for LG VX5300
well.. few old mobile phone antenna was easy to remover i remmber old day when my father use to own Erricson moble phone you can can the antenna and plug it out simply up wards but new phone i heard that we must unscrew them to replace the problem . better get it to the repair guy . i am sure he won't charge you much for this
Sep 03, 2007 | LG VX5300 Cellular Phone
Computers & Internet Logo
44 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
