Question about Midland 1001Z 40-Channels Base CB Radio
Cant hear i can transmitt but can not hear anything. any suggestions?
  • jwade_24 Jan 28, 2008
    thanks for the advice. the cb will transmitt but there is no deflection on the receiving side. listened to it on other cb's. gets out great but nothing coming back
  • 2,130 Answers
Several things can cause poor reception. I have a few questions for you.
1. Have you tried measuring your SWR (standing wave ratio)? This helps give you an idea how well your transmission line and antenna are working.
2. Is this radio being used as a base or mobile? Do you have proper grounding on the antenna?
3. Pressing the mic button and seeing the radio indicate "transmit" does not always mean you are transmitting at full rated power. Have you tried transmitting through a wattmetter into a dummy load?
4. If the transmission line is good and the antenna is good, then I would suspect that something may be wrond with the receiver's front-end (sensitivity).
Receiver sensitivity can be checked by using a RF signal generator. Unfortunately you'll have to take the unit to a repair shop to have that checked. Try the other things I mentioned above. Let me know what you find and we'll go from there.
Good luck,
- Jim
Posted on Jan 28, 2008
  • 1 more comment
  • SHARCNET-USA
    SHARCNET-USA Jan 28, 2008
    Also, if your radio has a RF gain control, make sure its not turned down. The RF gain control will affect the receiver's front end sensitivity.
  • SHARCNET-USA
    Another question: Do you hear any sound? Is the internal speaker ok? Do you see any deflection on the S/RF meter during receive? Many CB's have an external speaker jack. If you are not hearing any audio but see meter defection on received signals, try hooking up an external speaker.
  • SHARCNET-USA
    Then I would say, try to take the radio to someone with a RF signal generator. Typically, a CB receiver will have a sensitivity of 0.5 microvolts for 10 dB; (S+N)/N (without a pre-amp). To test the receiver, you set the RF level of the generator, very low (below .5 microvolts) and connect it directly to the antenna jack on the CB. You can also set up a 1 kHz tone on the generator that can be heard on the CB. Slowly, you increase the level until you can hear the signal on the CB. If you hear the 1 kHz tone pretty well, even though there is noice on the signal, with the generator set at .5 microvolts, this will give you an indication that the recever's front end is ok. If you have to increase the signal level of the generator to many times the level above .5 microvolts in order to hear a signal, this is an indication that the receiver's front end is bad. You can also try setting the generator to the CB's IF frequency and see if the CB will pick up that signal, which will tell you if the IF section is operatng properly.
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
I cant hear anything through my x41 headset
I can hear everything but myself on x41 other can hear me I just cant hear myself..
Mar 06, 2012 | Voyetra Turtle Beach Turtle Beach Ear...
Garmin 765T No sound for bluetooth phone
Have you tried to use a set of headphones to see if you hear anything?
Another check is to make sure FM Transmitter isnt checked
To do that Click Volume icon
bottom of screen you see FM Trans
click it
make sure there is no checkmark in Enable FM Transmitter
click back to main menu
Love my Nuvi760
Mar 29, 2010 | Garmin Nuvi 660 GPS Receiver
I cant hear any sound on my phone. only time i hear sound is when i get a call i hear the ringtont. but when i answer i can't hear anything. or even when i go to my sounds or ringtones and press play it...
First all I suggest you to format this phone as factory default, go in menu>>settings there is a reset factory default option select it; this will reset your phone to the default settings.
Make sure you loose all the data stored in phone.
Post further comments for more help.
Good Luck!!
Thanks
Jul 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Where to find Advent aw820 transmitter.
A phone number came, try 800 732-6866. I f that fails I usually suggest checking for a universal remote from the logictech harmony series for your unit.Search their website or call them directly to see if they have a unit that can be programmed.
Jan 06, 2018 | Recoton Advent Advent AW820 Computer...
We purchased a 03 lincoln lsand need to reset the keyless entry
1. Sit in the vehicle driver's seat.
2. Remove the ignition key from the ignition lock cylinder.
3. Close all of the vehicle's doors.
4. Remove the MALL PGM fuse from the fuse panel. Or reset the fuse which controls your keyless remote.
5. Turn the ignition lock cylinder to the ACC position.
6. Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
7. Open and then close any vehicle door. You will hear a chime when the
remote control door lock receiver enters the programming/diagnostic mode. If
you do not hear a chime, start again at step 1.
This is an important fact here:
After 7 seconds, you may hear a chime confirming successful synchronization.
After approximately 14 seconds, you will hear a chime confirming successful
programming.
8. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for
14 seconds.
9. Repeat step 8 in order to program each additional transmitter.
10. Remove the ignition key from the ignition lock cylinder.
11. Install the MALL PGM fuse back into the fuse panel.
This is important as well:
Once the keyless entry receiver enters the programming/diagnostic mode, the
programming of the first transmitter erases all previous transmitter
programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you
program multiple receivers simultaneously, the same transmitter could
possibly be programmed to more than 1 remote control door lock receiver
The fuse should be in your fuse block of your vehicle.
May 25, 2009 | 2003 Lincoln LS
THE REMOTE DOOR LOCK ON A 2000 BUICK CENTURY HAS QUITE WORKING. THE FOBS ARE GOOD BUT WON'T OPEN ANYTHING.
The transmitter may have lost programming,
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
IMPORTANT:
  • Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
  • Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity.
  1. Sit in the driver's seat.
  3. Close all vehicle doors.
  4. Press and hold unlock on the door lock switch.
  5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
  6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure.
  7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active.
  8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds . You will hear two chimes. This chime feedback indicates that the transmitter has been programmed successfully.
  9. Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
  10. Exit this procedure by removing the ignition key from the ignition lock cylinder.
May 07, 2009 | 2000 Buick Century
No response to radio check
Try this: find another CB radio and tune it into the same channel as the other one and talk on the one you have trouble with and if you hear yourself on the other CB, your radio is fine. But if no one can hear you, you might need to find a better antenna, I'd recommend Shakespear or Moonraker antennas. They're pricey, but worth the money.
However, if you still can't hear your voice on another radio, you may have either a Mic problem or a Transmitter problem. If so, use a different Mic and see if that solves the problem. If not, you may need to get another transmitter or new radio.
Best Regards,
Gavin93
Aug 05, 2008 | Radio Communications
Belkin TuneCast FM transmitter for samsung t9
I just bought this transmitter and i plugged it into the car and my samsung mp3 player and it will charge the player but you cant hear any music even when i tune it to a vacant radio station.
May 20, 2008 | Belkin TuneCast Auto FM Transmitter for...
Midland 1001Z 40-Channels Base CB Radio Logo
221 people viewed this question
Top Midland Radio Communications Experts
Steve
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
