Question about GE PTS25LBM Top Freezer Refrigerator
FREEZER AT 36 FRIDGE AT 31
THE MOTOR IS RUNNING BUT DONT HEAR THE COMPRESSOR COMING ON
  • STEF5765 Jan 28, 2008
    You hear the motor running, but dont hear the compressor come on. The freezer is defrosting, and the fridge is getting warmer. When you try to program the digital display, it programs, but never reaches the desired temp.
    Problem Solver:
  • 8 Answers
Motor might not be driving the compressor really dont know what you mean
Posted on Jan 28, 2008
I have a samsung fridge/freezer. Production date 2007. Model#RS20NRSV5/XSA both the fridge an freezer not getting cold The lights are on but no cold air.An cant hear anything working at the back.
Your compressor is not working that's why its not cooling and you cant hear anything.
Possible cause:
  1. thermostat is set to off or defective
  2. defective capacitor that's why your compressor failed to run.
  3. defective compressor motor
  4. Freon leak or no freon at all.
Solution:
  1. check thermostat switch or relay
  2. check capacitor and wiring.
  3. check compressor motor.
  4. Check Freon pressures.
May 11, 2016 | Samsung Refrigerators
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
WILL NOT COOL OR MAKE ICE. COMPRESSOR DOES NOT SEEM TO COME ON.
next time send the model number off of the fridge,side by side or bottom freezer model number is in fresh food section,right hand wall up near ceiling or on ceiling,top freezer look on left side wall.if the compressor isn't running most likely you have a bad start device located on the side of compressor,pull out the fridge,unplug it,remove the back outside bottom panel and you'll see the compressor,pop off the metal clip,remove the cover and slide off the start device or overload and relay same thing,then shake the device,if you hear pieces rattling around inside it it's bad,easiest way to check it,if you open the freezer door and you hear the fan blowing around most likely this will be your problem,you might hear the compressor clicking trying to start and it will be hot,also vac out the condenser coil and make sure the condenser fan motor is running good,over heating can take out the start device.good luck.
Jul 05, 2012 | Frigidaire Refrigerators
Freezer and fridge quit cooling. The fan works and the display reads 58 degrees for both. The tstat setting is -2 for freezer and 36 for fridge. sounds like compressor isn't running. any suggestions?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Samsung RM255LASH Side by Side...
My fridge wasnt cold yesterday but the light was on and the freezer worked but this morning the freezer has started to defrost and everything was warm in the fridge
If you cant hear the compressor running and he fan under the fridge and in the freezer compartment are not running. The problem would be your defrost timer has quit on the defrost mode. Your defrost timer should be located in the fridge side behind the back plastic liner or if your controls and light are in the center top it will be there. The timer is plastic with a metal motor on one side. There is a shaft in the center that a flatblade screw driver will fit in turn it and you will hear audible clicks and the fans and compressor should kick in. I hope this helps. If the fans are working but the compressor is not the compressor is bad or the start relay on the compressor may be bad it is located under a plastic cap on the compressor and is about the size of a nickle and is connected to one of the 3 prongs coming out of the compressor. Remember to always unplug the fridge before working on it. good luck
Aug 18, 2010 | Refrigerators
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
The refrigerator and freezer are not getting cold but I can hear the motor running.
Hello there:
If the compressor is running and you can hear it than you are going to have the refrigerant recharged in the unit.
If you continue to run the unit without refrigerant you will end up with the compressor quitting and this you do not want ok?
I hope this has been very helpful for you ok?
best regards michael
Nov 05, 2009 | GE Profile Arctica 25.4 Cubic Feet...
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
GE PTS25LBM Top Freezer Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
