Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0  Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any way to format a laptop without a battery?I have a hp compaq.the problem is i tried to format it and install a new operating system in it. but after formating and copying all the necessary files and have to restart, it goes off and have to start the whole process again
Anonymous
Level 2:
New Friend:
  • Expert 46 Answers
  • Posted on Dec 28, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
46
Questions
0
Helped
11480
Points
138
The laptop should not require a battery if it is plugged in to the charger. The electricity flows directly into the components and then into the battery on almost every laptop, so you should be able to format it without the battery if its plugged into the charger.
Mark Taylor
Level 3:
  • Master 728 Answers
Mark Taylor
Master
Level 3:
Answers
728
Questions
0
Helped
335394
Points
2225
After you format the drive you need to go to DOS and load DOS with CDROM support, then launch Windows through the command prompt
D:\I836\winnt.exe
the D may be another drive letter, but that should start your install.
Good Luck
Mark
Just installed new hard drive now my laptop does not want to start
need to format new hard drive then install an operating system.
1helpful
How to format a compaq
Formatting is used to erase yourhard drive. Many times, this is used to clean a hard drive after a virus or toperform a completely clean installation of a new operating system. A Compaqlaptop can be easily formatted, but formatting will only solve system problems,not hardware problems. The process should only be used to solve problems as alast resort, since it will erase all of your data.
1. Back up all data before performingthe format (if possible).2. Insertthe operating system disk and restart your computer and wait until prompt fromthe system.3. Strikeany key when prompted to begin running the disk.4.Choose between reinstalling yoursoftware or repairing. Reinstalling will allow you to format and thenreinstall. Repairing will bring you to a DOS menu. You will need to use FDiskwith each individual drive letter on your hard drive. Use this option if youhave a multiple partitions on your drive and only need to format a singlepartition.5.Choose "Full NTFS" formatif you choose to reinstall the operating system.Remember:Most users will only need to use thereinstallation option. This option is perfect for users with one partition orthose reinstalling or upgrading their operating system.
Never format your Compaq laptopwhile on battery power. If the battery dies during the format, you could ruinyour hard drive.Hope this helps, pleaselet me know if you need further assistance.Please don't forget to rateand comment if my solution was helpful, thanks!
2helpful
2answers
My hp compaq nx 6110 keeps hanging, what are the thing i can do to stop this hanging to permanently
For the starters I would suggest re-installing new Operating System. If that will not help, then there is a chance that you have faulty Hard Drive, RAM or even motherboard. In that case you will need to make diagnostics for all possible components or just give to repair shop.
My sound drive of n*7300 laptop is not working. I have to download it now
these kind of problems which are transmitted to your windows or operating system used is much error, a way to re-operate it will re-format your laptop or install new windows.
GL
Need to get to dos to fix stop codes for windows for compaq nx902
if it gave you blue screens and its is stoping for no reason ...just save tha data ..and reinstall the operation system ...format in ntfs normal way all the C partition during this installation and it will be ok ...
if after this still does it ...its not from the operation system and it is probably the Ram memory or a hdd issue.....usually they do not do this after a clean installation with C formatting during ...(format D partition after ...in the same way ..I mean slow not quick format )
I have a toshiba satellite and i am getting a blank screen with a cursor blinking in the top left corner
Try remove everything that attached on your laptop, Flash Disk, Floppy Disk, CD-ROM, or anything, just the laptop only without anything.
If still won't operate, it's the operating system crashed, try reinstall it with new ones, and you must format the Hard Drive during installations
While doing the formating sound driver has deleted
Here follow the link and select the currently installed Operating System in your Notebook PC and download the sound driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3369431&#
1helpful
I can't format my 32gb pen drive.Window unable yo format it
Try to use this program to format it.
Utilityfor formatting and creating loading USB Flash (it is supported NTFS,FAT, FAT32). It works with the devices through port USB 2.0. For theload from flesh in BASIC INPUT-OUTPUT SYSTEM Setup it is necessary toestablish as the first loader USB-HDD Device. m_right_m.gif banner_header m_right_m.gif VERSION: 2.1.8 Rev. A
DESCRIPTION:
This SoftPaq contains a Windows-based format utility for the HP Drive Key or
DiskOnKey USB 2.0 device.
PURPOSE: Routine
SOFTPAQ NUMBER: SP27608
SUPERSEDES: SP27213, SP27135
EFFECTIVE DATE: May 17, 2004
CATEGORY: Driver - Storage
SSM SUPPORTED: No
PRODUCT TYPE(S):
Desktops
PRODUCT MODEL(S):
HP Compaq d220 microtower: All Models
HP Compaq d230 microtower: All Models
HP Compaq d240 microtower: All Models
HP Compaq d248 microtower: All Models
HP Compaq d330 desktop: All Models
HP Compaq d330 microtower: All Models
HP Compaq d330 slim tower: All Models
HP Compaq d338 microtower: All Models
HP Compaq d530 convertible minitower: All Models
HP Compaq d530 small form factor: All Models
HP Compaq d530 ultra-slim desktop: All Models
HP Compaq d538 convertible minitower: All Models
HP Compaq d538 small form factor: All Models
HP Compaq dc5000 microtower: All Models
HP Compaq dc5000 small form factor: All Models
HP Compaq dc7100 convertible minitower: All Models
HP Compaq dc7100 small form factor: All Models
HP Compaq dc7100 ultra-slim desktop: All Models
HP Compaq dx2000 microtower: All Models
HP Compaq dx6100 microtower: All Models
HP Compaq dx6100 slim tower: All Models
HP Compaq dx6120 slim tower: All Models
HP d325 microtower: All Models
HP d325 slim tower: All Models
HP RP5000: All Models
N/A: All Models
OPERATING SYSTEM(S):
Windows XP Home Edition
Windows XP Professional
LANGUAGE(S):
Global
ENHANCEMENTS:
New Windows-based interface. (For DOS-based interface, download SoftPaq
SP27214.)
FIXES:
- Allows creation of a FAT32 volume larger than 32 GB.
- Fixes installation issue where installation process stopped after the earlier
version of software was uninstalled and the new software was not automatically
installed. The installation process now restarts automatically to install the
new software after uninstalling the older version.
PREREQUISITES:
- Requires an HP Drive Key or DiskOnKey device plugged into a USB 2.0 port.
HOW TO USE:
1. Plug the HP Drive Key device into an available USB 2.0 port.
2. Download the SoftPaq .EXE file to a directory on your hard drive.
3. Execute the downloaded file and follow the on-screen instructions. If
prompted to overwrite any files, answer Yes to all to continue installation.
http://www.maxiwarez.com/2007/12/21/hp_usb_bootable_format_tool_v.2.1.8.html
3answers
HP Compaq Notebook nx9010
Hi, I can help you with this. What operating system are you trying to load?
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
