Installation problem when i installing Mac OS X on my system i am facing some troubls, that is HARD DISK is not recognising  please tell me how to install MAC OS X on my system.
  • Anonymous May 11, 2010
    Which computer are you trying to install on?
  • Anonymous Mar 20, 2014
    i installed torch software to my mac and it wont install
    Champion:
  • 217 Answers
Are you trying to install it on a Macintosh or Windows laptop?
Posted on Jan 28, 2008
6ya staff
SOURCE:
I got a grey screen flashing a folder and other symbols on my IMAC OS X 10.5
Hi joe_shadowla, this means the Operating System has trouble finding the startup disk and the OS needs to be reinstalled. You need to have your OS X Install Disk equivalent to 10.5 or higher:
1) Insert the disk and wait for it to load to the Welcome screen
2) On the menu bar go to tools and click on Disk Utility
3) Click on your Hard Drive on the right and click on the Erase tab
4) Make sure it say (Mac OS X Extended-Journaled
5) Erase the Disk and Exit
6) Proceed with the installation and follow the onscreen instructions.
Mar 05, 2013 | Apple Mac OS X 10.0.3 Operating System &...
I got mac g4 just got face and ? on it, any have idea what going on it
Typically this is operating system corruption or a failed hard drive. If you can boot to your install media (CD, USB, or recovery partition) try a clean install. You could also try third party software solutions like Disk Warrior or Drive Genius (they supply bootable media) to fix the OS issues or check the disk for failures / corruption
Oct 16, 2012 | Apple iMac G4 Desktop
I have mounted a new 40GB on my imac G3 and wanted to install OS ssw 9.0.4 on it, but at start up from the CD, it booth up to where it suposed to show the os type having this icon like a human faced pc at...
Thank you for contacting Fixya Support, I am glad to assist.
The "human face" icon is an indication that your hard drive is not being recognized by your iMac G3 because the hard drive is not formatted to read the Mac OS 9 software.
What you need to do is initialize your hard drive so you can
it can read the Mac OS 9.0.4 software.
Below, I have provided a link with simple steps to properly initialize (format) your 40GB hard drive
Initializing a hard disk, cartridge, or optical disk
Follow these steps and you will be able to successfully install Mac OS 9.0.4 to your Mac G3 hard drive.
I hope this helps.
Regards,
-Mactechtrainer
Aug 28, 2010 | Apple iMac G3 Desktop
My Powerbook G4 turns on light, fan, chime but no video.
Your hard drive has lost a file needed to start up the machine. The folder with the question mark means it cannot find a useable Operating system. I hope you backed up your files you needed becuase the only real way to recover the machine is to reinstall the OS from the install disk. You must format the Hard Drive from the format option on the install disk and reinstall the OS.
May 08, 2010 | Apple PowerBook G4 Mac Notebook
My power book g4 will not start up it goes on with a white screen and the apple sign with the wheel spinning than it goes off
Please boot the system with a Mac OS X installation Media .Insert the installation media and power on the system and immediately press ' C ' key to boot it from Mac OS X installation disk.After few seconds the language selection option will appear .Click continue and then in the next screen see on top you will find "UTILITY" then click "DISK UTILITY" .Select the boot drive partition and try to repair the file permissions mentioned left hand side .If the permission repaired successfully then restart the system and check if it boots.If still you face the same issue then reboot the system with installation media again and repartition the harddrive .Install the os Freshly.The issue will get solved
Apr 10, 2010 | Apple PowerBook G4 Mac Notebook
Hard disk crashed on macbook
You can tell if your hard drive for your Macbook Pro has really crashed, if you attempt to run these 3 diagnose and repair procedures and there is no response from the hard drive:
1st Procedure:
font.f1 {font: 12.0px Helvetica} font.f2 {font: 14.0px Myriad Pro} - USING FSCK COMMAND TO VERIFY AND REPAIR DISK-
Start up your computer in Single-User Mode to reach the command line by doing this:
•Make sure your Mac is shutdown.
• Reboot your Mac
• When Mac starts up, press the Apple Command key+ S Key
- A black screen, with white text appears
• At the command-line prompt, type /sbin/fsck -fy
• Press Return.
--fsck will run through a series of tests and will return information about your disk's use and fragmentation. When completed, it will display this message if no issue is found:
The volume (name_of_your_Mac_volume) appears to be OK
If fsck found issues and has altered, repaired, or fixed anything, it will display this message: --FILE SYSTEM WAS MODIFIED--
Important: If this message appears, repeat the fsck command you typed at the beginning, until fsck tells you that your volume appears to be OK (first-pass repairs may uncover additional issues, so this is a normal thing to do).
• When fsck reports that your volume is OK, type reboot at the prompt and then press Return.
• This last command after completing the fsck process, is going to attempt to boot your Mac to the main desktop.
If unable to reach your Desktop with the fsck procedure, go to the next step.
Procedure # 2
font.f1 {font: 13.0px Myriad Pro}
-RUN DISK UTILITY WITH STARTUP DISK-
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
* If you have still not gotten a successful boot to your main desktop, try this final step.
Procedure # 3
My recommendation for this issue, is that you use the Archive and Install procedure to resolve this issue.
What this process consists of (using your Mac OS X install disc),is removing the damaged or corrupted Mac OS X directory and replacing it with a brand new directory.
This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files.
-ARCHIVE AND INSTALL-
• Start up from your Mac OS X Install Disc 1 or Install DVD. Please remember to use the install disc that matches the current operating system your system haves.
Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key.
• Hold the C key until you see a White screen, with a Gray Apple icon and eventually a Spinning gear.
-Your mac will now boot from the disc and load into the Installer environment.
• Select your language. The Welcome to the Mac OS X Installer window appears.
• Click Continue. The Important Information window appears.
• Follow the prompts until you get to the licensing agreement screen
• An agreement sheet appears. If you agree with
the license agreement, click Agree. Then Select a
Destination window appears.
• Click the volume that you wish to install to (your primary hard drive).
• Click Options. The installation options sheet appears.
• Select Archive and Install.
• Select the volume which already has Mac OS X installed.
• You should also select Preserve Users and Network Settings, to preserve network and Home directory settings.
• Click OK.
• Click Continue to begin the installation.
• Once the Archive and Install is completed, when you reach your desktop be sure to run all Software updates to bring your new Mac OS X directory back
up to current.
Also, if you look inside your Macintosh HD icon on your Desktop, look for a folder entitled "Previous System Folder" which will have all of your previous Home folder files prior to the Archive and Install.
Here is the link (below) from Apple for more information about how to locate the Previous System Folder
How to locate Previous System Folder (after Archive and Install)
If there is still no responsiveness of the hard drive after this last procedure, your best option would be to take your Macbook Pro in for repair or replacement of the hard drive, to your local Apple retail store Genius bar or local Apple authorized service center.
Best Regards,
-Mactechtrainer
Jan 29, 2010 | Apple MacBook Pro PC Notebook
I picked up a Powerbook G4 12' Aluminum guesing 1.5 from a local college that was going to trash it, and when I press the power button the start up chime rings and turns straight to a blinking ?/Mac OS...
Get the gray OS discs specific for the PowerBook. Your iBook gray discs won't work. You can also install the OS by getting a black label retail version disc of whatever cat you like- Panther or Tiger. If the software installs, but you hear noises or get the spinning beach ball of death, then the hard drive is fu.k.d up. You then have to open up the computer and install a new hard drive and re-install the OS. Good luck old chap. Cheers.
Dec 31, 2009 | Office Equipment & Supplies
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
OS X Leopard
If your computer rejects the Mac OS X Installation DVD, it means that there's a good chance that your Mac doesn't have an Apple internal DVD drive or an Apple SuperDrive, you'll need Mac OS X 10.4 Install CDs.
If your mac is unable to read the CD or ejects it also, there's something wrong with your DVD\CD drive.
You might want to try loading the DVD on a second computer that is connected with a fire wire to the first computer.
Good luck.
Aug 28, 2008 | Apple Mac OS X 10.4 Tiger for Mac
File folder?
What you are seeing is the Mac's PROM telling you that it cannot find the "System Folder" The System Folder contains all the components of the operating system itself.
You have an option to boot from the install disks that came with your machine. Boot from the CD/DVD disk by holding down the "C" key. (Usually, this is not required. The Mac is smart enough to look on all connected devices to find a viable System Folder.
Anyway, once you have booted from the CD, you MAY be able to use Apple's "Disk Utility" or, if it's there, "Tech Tool" to repair the laptop's drive.
If you are unable to repair the drive, and, if it's not be physically damaged in some way, you should be able to re-install the OS.
This would be a good time to think about getting an external drive, and a copy of CC Cloner by Mike Bombich, and setting up a backup regimen.
ciao
Dec 16, 2007 | Apple iBook Mac Notebook
Open Questions:
Computers & Internet Logo
133 people viewed this question
Ekse
Marvin
Marvin
