Question about Liebherr Premium CTP 3153 Top Freezer Refrigerator
Bottom hinge on fridge door broken
The bottom hinge on fridge door is broken.
I think it might be a plastic spacer as the door has sunk onto the hinge and now won't open or shut unless you lift the door up whilst closing or opening.
  • Anonymous Mar 17, 2014
    The door makes a loud thudding noise with a jolt that inhibits smooth closing of the door. Makes you think that there is something very heavy in the door and it's straining the hinges. Now I've noticed that there is black plastic on the floor near the hinge where apparently something is breaking and falling off.
  • Anonymous Mar 24, 2014
    Kenmore model 106, fridge door will not shut unless you close it manually
  • 29 Answers
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
How do I replace the bottom socket where the door hinge slides in
I assume you mean the hinge that is on the cabinet and not the door? If its the door part that has failed, you will need to get a new door. If its the cabinet hinge, some of these are screwed onto the cabinet from underneath the fridge. Others however, are mounted inside the cabinet and are not really designed for replacement. Ive fixed a few over the years on different brands where the plastic hinge has broken but it can be a bit messy. The cabinet needs to be carefully peeled or bent back on the bottom corner of the fridge to access where the hinge is mounted. Unscrew the hinge and if you are lucky, the Manufacturer has these as a spare part. If not, the only way is to go to a hardware or cabinet parts store to try and source something that will suffice. Do NOT be tempted to put a normal gate or door hinge onto the fridge door and screw it onto the cabinet. Inside the cabinet especially around the edges are whats called "mullion heater" pipes or in older fridges, mullion elements. If you screw through a pipe, you will lose the gas and fridge will be shot. If you screw through an electrical mullion heater, there is a danger of electrocution.
Dec 23, 2014 | Dometic RM2852 Refrigerator
Amana drs2663bw door draging on bottom
Was the door taken off, when it was moved into it's place? A spacer might be missing at the hinge, or the door was knocked out, of adjustment. Look at the hinge. There should be some kind, of adjustment, if the all of the spacers are present.
Aug 16, 2014 | Amana Refrigerators
My fridge door is not closing tightly without force
The bottom hinge has spacers. Perhaps a spacer or two have worn out. Remove the bottom hing and see if there are any spacers if not a hardware store could get a couple for you. Install them and this should raise the door hopefully to clear the liner. The only other thing is the hinge pivot is just worn out. This is more complicated to repair
Jul 30, 2014 | Kenmore Refrigerators
My refrigerator door does not come up high enough to push in the button when it closes, so the alarm keeps beeping to signal that the door is not shut. I thought if I removed everything from the door,...
You may have one of two problems, you either have too many spacers on the top hinge or not enough spacers on the bottom hinge. With the door on, measure the amout of of distance the door has to come up in order to close properly, say it's 1/4". That being the case, remove door from fridge and install a 1/4" plastic washer over the bottom hinge pin which holds the door in place. It may be necessary to remove a spacer from the top hinge in order for the door to close properly after installing the new bottom spacer, or you may get lucky enough to just take one from the top hinge and put in to the existing hinge spacers on the bottom. Reinstall door and check for proper closure and allignment. Hope this solves the problem.
Kenny
Dec 28, 2013 | Kenmore Refrigerators
How do i fit the door on the other side
If you look at the opposite side of your refrigerator, you'll find one or more plastic covers which can be removed to expose mounting holes. You have to remove the doors from the current mounting position, remove the hinges and transfer them to the other side, install the doors and you're done
Jan 25, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Plastic bottom door spacer broken
bottom plastic door spacer is pt # WR01X10297 COST 7.35 . TO REPLACE OPEN DOOR AN SUPPORT / REMOVE BOTTOM HINGE PLATE AND REMOVE . REVERSE TO INSTALL . hope this helps mm parts are found and any appliance dealer or on the web at several dist . .. feed back pls ..
Dec 11, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Fridge door not closing properly
This section of this refrigerator door repair guide will walk you though repairing a refrigerator door on a side-by-side refrigerator. On most side-by-side refrigerators there is a cam that lifts the door up when you open the door so that the door has a tendency to fall down and back into place while it is closing. If the refrigerator has a cam and it is working properly, the refrigerator door will rise up when you open it and lower when you close it. If this cam is broken the door will not close properly. A lot of refrigerators have two cams, one screwed on the door and one on the hinge. You may have to replace the entire hinge to replace the lower cam but the cam on the door can always be replaced. You will have to order the cam by model number and can do so on this website AppliancePartsPros.com.
On side-by-side refrigerators without cams there will be a spacer on the door hinge. If this spacer is missing replace it. Note that any plastic spacer will work as long as it will go on the hinge pin and is not too thick. Never use a metal spacer because this will cause wear on the door and it will eventually squeal when closing.
As on top-freezers the door gasket may be ripped and if so refer to the bottom section that talks about door gasket replacement.
Sometimes the door can get warped out of shape. If the door is closing at the top and not at the bottom or vice versa the door may be warped out of shape. You can fix this by twisting the door back into shape. Take you foot and place it at the bottom and pull the door out at the top or place your foot inside the door at the bottom and push at the top with your hand depending on which way you need to twist the door. Note don’t over do it twist it a little and if it isn’t enough twist it a little more. If it gets worse you may need to twist the other way.
hope this helpout ......
Aug 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do i remove the door from a side by side ge fridge , the bottom spacer has broken in half and the door will not close without lifting it.
Don't need to remove door, just get new piece, then block door up remove hinge and replace, just be sure to keep door closed and lighten it up by removing food from it..
Jan 03, 2010 | GE Refrigerators
Liebherr Premium CTP 3153 Top Freezer Refrigerator Logo
948 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
