Question about Dell OptiPlex GX260 PC Desktop
Diablotek radeon 9200 problems.....please help
I have a GX260 PC, and I am trying to install and use a Diablotek radeon 9200 graphics card. It says in the directions to have SP3 installed, I do. It also says to disable the current graphics controller, in my case the intergrated one, I did that as well. It then says to turn of the pc, and install the card, then plug the vga into the card and turn on the pc. So I did all that but when I turn on the computer, I dont get any kind of input from the pc, the screen is blank and says no signal. I try plugging in another monitor at the same time to the intergrated vga port and nothing will show up on there either....so I am lost and hope to get to work, because of the cad work that I do. I would appreciate any help. thanks
by the way the computer is not in original small case, and it has a different power supply, but it is the gx260 main board
  • 1 more comment
  • skypirate Jan 28, 2008
    Ok, I turned off the computer, and by remove and replace, do you mean get a new battery or just put it back in? I just put it back in. The card was installed when I turned it back on after the battery replace and there was still no signal from the PC. The only options for the video stuff, is AUTO or ONBOARD in the bios setup. Also, I forgot to mention, the card is AGP not PCI. Now what?
    ok, did all that and that was a no go as well:( there is an option in the bios that is turned off in the itegrated devices section called VIDEO DAC SNOOP. what is this for? would it help anything if it was ON?
    ok well problem is still not fixed, so do you have anybody you could refer this question to?
    Scholar:
  • 79 Answers
OK, turn-off the computer, remove and replace the BIOS battery, then start it up with the VGA cable in the onboard graphics port.
Press the corresponding key to go into BIOS setup (Del?) and go to the Integrated Devices menu.
Change the option from onboard to PCI in the Video options.
Exit and save settings. As the computer restarts (you'll have to be quick) swap the VGA cable back to the Radeon's port.
Posted on Jan 28, 2008
  • Cory
    Cory Jan 28, 2008
    Of course - set it to AUTO. Restart with the cable in the Radeon's port. If this doesn't work, go through what you just did, replacing (as in; take it out and put it back in again) the BIOS battery (with the power cable removed, so that all power is drained in order for the BIOS to be reset). Start the computer with the cable in the onboard port, go BIOS settings, change to AUTO, then Save & Exit, swap the cable and hopefully, you're away.
  • Cory
    Cory Jan 28, 2008
    Hmm, worth a try.
I have that card but i don't have drivers of this card i installed windows 2008 xp professional service pack 3 when windows complete its installation it would automatically install driver but these...
Your card is old but you can find the drivers for xp at this link https://support.amd.com/en-us/download.Go to manually select your driver step 1 desktop graphics step 2 Radeon 9xxx series step 3 radeon 9200 step 4 select your operating system and hit diplay results.
Sep 06, 2017 | ATI RADEON® 9250, (128 MB) AGP Graphic...
I can't get a driver software of ATI moblity radeon HD 9200 how can i get it? can someone help me how get that software thanks
1. May i know what operating system you are using right now? Windows vista or windows 7
2. You have to download .net framework just type on google .net framework then download and install the software.
3. After installing .net framework go to this website and choose ATI RADEON 9200 and your operating system you used right now!
4. Download and install the ATI RADEON 9200 after installing it will require to restart your computer just restart to update your system settings. Have a good day!
Dec 07, 2010 | ATI RADEON 9200 Graphic Card
I m using Radeon 9200 series card with Intel Atom 1.66Ghz, the Radeon driver version is 8.252.0, I observed display flicker & GIF icon blur issue intermittently, please help me!!
TRY TO REMOVE THE DISPLAY CARD FROM THE PC AND CLEAN IT AFTER CLEANING IT PUT THE DISPLAY CARD AGAIN OR IF U HAVE A ON BOARD DISPLAY PORT TRY WITH THAT AND CHECK THE OUTPUT IF THE PROBLEM PERSIST THEN IT SHOULD BE WITH THE MONITOR OTHER WISE WITH THE RADEON CARD TRY THIS WILL HELP TO SOLVE THE PROBLEM
Nov 16, 2010 | ATI RADEON 9200 Graphic Card
I have a ATI Radeon 9200se m61d128x20jy 128mb agp
hi try to download this software and hopefully ur problem will be solved http://www.driver-download.net/ati/video-adapters/radeon-9200-se-128mb-ram/
Jun 07, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
Cannot play FIFA09
Uh oh. It looks like you're out of luck.
FIFA 09 PC Requirement (minimum):
Graphics: 6600 Nvidia graphics card or ATI equivalent with support for Pixel Shader 3
DirectX Version: DirectX 9.0c"
Nvidia 6600 came out at 2004 and it supports DirectX 9.0C (Shader 3 came with 9.0C)
ATI Radeon 9200 came out at 2003 and only support DirectX 8.1 (which support shader 1.2 - 1.4)
Nope, Radeon 9200 will not support Shader 3 (neither will it support 2.0).
Time for a new video card maybe?
I hope this answers your question.
Mar 16, 2009 | ATI RADEON 9200SE Graphic Card
I put my ati radeon 9200 and windows xp sp2 install the sis315
Try to to download and install the latest Radeon drivers
You will find the drivers here:
http://ati.amd.com/support/driver.HTML
Just follow the steps on that site, select your OS etc
I think that will solve your problem
Good luck to you
Please take a minute and rate my answer
Nic
Feb 06, 2009 | ATI RADEON 9200 Graphic Card
No color on secondary display
Dear Huzzah,
please try to re-install the software( driver) of Radeon 64mb 9550/X1050 secondary series maybe the software is crroupt, if still face the same problem then please contact to Vendour to replace this card, if this card is in warranty period.
Regards
Scorpionakku
Oct 07, 2008 | Diablotek RADEON 9550 Video Card - 64MB...
ATI Radeon mobility Graphics Card 9200 Drivers for VISTA
http://www.opendrivers.com/driver/240370/ati-radeon-graphics-card-driver-catalyst-7.11-windows-vista-x32-english-free-download.html
Dec 03, 2007 | ATI Mobility RADEON Graphic Card
Dell OptiPlex GX260 PC Desktop Logo
128 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
