Question about Dynex DX-E401 Router
Dynex 4 port mbps hub
The problem is when I try to connect my xbox 360, it's having a problem reading the ip address. I tried so many times and nothing seems to change.
  • 112 Answers
Try a certified live Hub see list on Xbox.com.
link below.
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Posted on Feb 25, 2008
6ya staff
SOURCE:
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Dec 29, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
I just got this dynex 4 port ethernet hub and i have comcast wired internet . and i want to hook it up to my xbox 360 and my computer but , it wont let me . when i try to get xbox live it says network...
You need a router not a hub or a switch. with the help of the router you can share the comcast cable internet on multiple devices. A hub or a switch can not do this.
Get it replaced with a router. You can buy Linksys or Netgear router.
Rashish
Aug 17, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Cant find IP address
You need to make sure that DHCP is turned on for the router and the the Xbox is set to automaticallly get network settings. If not, then you will need to manually configure the adress and settings. If this is the case, please post back the address of the router and all other devices on your network and we can help you make a suitable choice and get it configured.
Aug 15, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Dynex 4 port hub xbox 360 IP address error
Here is a link to their Support site: http://support.xbox.com/support/en/us/nxe/default.aspx Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Xbox 360 and computer connection.
No you do not. What you need to do is go into the xbox settings and turn on networking. It's kinda buried but it's in there.
Apr 21, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Dynex 4 port Hub
Try to assign an IP address to the second computer like 192.168.0.101 Subnet 255.255.255.0 and Default gateway 192.168.0.1
Note: This one is an example of IP address, the IP address that you need to assign is in range to the router that you have or with in range to the modem.
Mar 08, 2009 | Computers & Internet
Dynex dx-ehb4 will not change ip addresses
I am not familiar with that router so I will provide general knowledge and you can apply it to fix your problem.
It sounds like your cable modem is willing to supply a single IP address. This can and should be connected to the WAN port of your router. The problem is that the router is not assigning IP addresses to the equipment that is connected to its LAN ports. Instead, it allows that single cable modem IP to be assigned to connection #1 and everybody else gets nothing. Get the computer working through it, connect to the router as per the owners manual and turn on NAT or DHCP, whichever it offers. Reboot the computer and connect xbox and you should be good. This was probably not an issue with DSL because your DSL modem would supply up to about 10 IP addresses and they also passed through the router.
Mar 03, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Computers & Internet Logo
Top Dynex Computers & Internet Experts
gggg
Prashant M
Prashant M
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
