Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
D-link DI-604 H/W Ver F4 F/W Ver 3.14 Made in China - Firmware download
I just bought this Router so as to share my internet conection. This device operates well as per network level but the PPoE conection is not distributed at all to any of the systems. The PPoE conections statusn the D-link indicates conected and none of the system can browse. Another D-link DWL 2100 and Unicorn IPN 5400G has been tested on the connection and they both work. I later discovered that the date on the Router can not be set beyond 2007. The simulation page for the same router on D-link site goes beyond 2012 so I decided to upgrade the firmware.
 I've searched the net (d-link sites except china since I cant speak chinese) and the closest firmware I could gef is Ver F3
 and that was for the DL-604 made in another country.
Can I load this?
  • 4 more comments
  • banjidaniels Jan 28, 2008
    Thanks
    Thanks
  • banjidaniels Feb 02, 2008
    Thank you all. The firmware from D-link Russia solved the problem. I appreciate.
    BanjiDaniels
  • chery2006 Feb 22, 2008
    My problem with DI-604 F3 3.14 is it slowed down my internet connection to below 200kbps. Without this router, I could get my subscribed speed of 2mbps. I seached in the internet for this model and found out from the d-link site that they stopped supporting this product. This product is made in China and being sold here in the Philippines. When I looked at the D-link websites, they only support products from Mexico, Canada and the U.S. There is no contact information for a local office in my country.
    I don't know if it is okay to download an updated firmware like what banjidaniels did.
  • triojamesoir Jun 11, 2008
    I have the same firmware version, and the problem is the IP needs to be released and renewed everyday...
    i thought of upgrading and maybe the UK FW should be fine... but just in case, is the FW from Russia in english format? That's just in case the UK firmware fails.
    Thanks for this forum!!!
  • itcomlink Nov 21, 2008
    i bought a d-link wireless DP-G310 print server.i after i finished configuring the server setting it works, but after second day i was trying to print a document from i discorverd that the print server couldnt communicate to printer anymore, i was tryin as much i can to reconfiguring the d-link print server nothing work again. please i cant reconmend d-link made in china product to anybody again because it was mest up all work in a client premises ..........
    Problem Solver:
  • 17 Answers
Me DI-604
H/W VER F4
HELP FOR FIRMWARE
Posted on Apr 25, 2008
I think Dlink has to stop selling its router Model DI-604 for lack of availabble customer support.
Posted on Apr 05, 2008
My router d-link DI-604 is constantlya unplugging... and disconnecting from internet
Check you have the latest firmware and also check you haven't set idle time out (it should be 0 = always on)
Also see if there are other routers in the vicinity especially n-routers which will knock it offline so you should change the channels.
Aug 29, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I have D-link cable router(DI 604)..i want to
http://www.antifart.com/2006/09/02/d-link-di-604-firmware-rev-e.html
Before using these files, make sure you have the E Revision of that router, you can check by looking on the sticker that contains all the model information like serial, model number.
Be careful while doing a firmware upgrade, very easy to brick your router. Bricking refers to making the router no more useful than an expensive paper weight.
Oct 20, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be 192.168.1.1, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Mar 12, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Any idea where to download the DI-LB604 firmware ver 1.01 ?
The following site has a 1.02 beta version of the firmware:
http://ftp.dlink.ru/pub/Router/DI-LB604/Firmware/
However, it also has the flash utility.....you could most likely save the firmware from your 1.01 router then use the flash utility on that site to flash the firmware you just saved to your 1.00 router :c)
Thanks and please take a moment to rate as fixya.
Dec 19, 2008 | D-Link DI-LB604 Router (DILB604)
D-link DI-604 installing
The 192.168.0.1 was probably changed when it was first set up. To return it to default settings take a paper clip and insert it in the reset hole in the back of the router.
Give it a few moments to reboot and the 192.168.0.1 address should work.
Oct 04, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-link di-604
I have no success disabling the DHCP server. For me at lease, this will not work
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-link DI-604 problem
I had a same problem a couple of years ago with a DLink router and upgrading the firmware solved it.
The Philippines are covered by DLink's Australian office.
http://www.dlink.com.au. Look in the Support section, you will find the latest firmware and instructions on how to upgrade it.
If you don't find what you are looking for on their tech support web site, you will at least be able to contact them from there.
Feb 22, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
New firmware..now problems
Does your office require VPN passthru to be enabled on the router? Did the firmware update reset the VPN passthru setting blocking your access?
Dec 07, 2007 | D-Link Express EtherNetwork DI-604 Router
Upgrade firmware
Step 1. Create a Folder on the Desktop Screen: From a blank spot the Desktop Screen, press and hold the Control key on the keyboard and click the mouse button. Release the Control key, click New Folder, and name it firmware. Step 2. Retrieve Firmware from Website: Click link below and download file to the folder created in step 1. Download DI-604 Firmware here - http://support.dlink.com/products/view.a... Download Di-614+ Firmware here - http://support.dlink.com/products/view.a... Step 3. Upgrade the Firmware: A. From the Main Desktop Screen, launch Internet Explorer or Netscape. B. Type 192.168.0.1 in the Address bar and click Go. C. For the User ID, type admin and click OK. D. Click Tools on the top and then click Firmware on the left side. E. Click Browse>Desktop>firmware, double click di6xx_firmware_203.bin and click Apply. Wait for approx. 15 seconds or until the M2 light stops flashing on the DI-6xx unit then click Continue. F. This takes you back to the Tools page. Check the Current Firmware Version on the Tools page to confirm that the firmware loaded successfully.
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
Upgrade firmware
Step 1. Create a Folder on the Desktop Screen: From a blank spot the Desktop Screen, press and hold the Control key on the keyboard and click the mouse button. Release the Control key, click New Folder, and name it firmware. Step 2. Retrieve Firmware from Website: Click link below and download file to the folder created in step 1. Download DI-604 Firmware here - http://support.dlink.com/products/view.asp?productid=DI%2D604#firm Download Di-614+ Firmware here - http://support.dlink.com/products/view.asp?productid=DI%2D614%2B#firm Step 3. Upgrade the Firmware: A. From the Main Desktop Screen, launch Internet Explorer or Netscape. B. Type 192.168.0.1 in the Address bar and click Go. C. For the User ID, type admin and click OK. D. Click Tools on the top and then click Firmware on the left side. E. Click Browse>Desktop>firmware, double click di6xx_firmware_203.bin and click Apply. Wait for approx. 15 seconds or until the M2 light stops flashing on the DI-6xx unit then click Continue. F. This takes you back to the Tools page. Check the Current Firmware Version on the Tools page to confirm that the firmware loaded successfully.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
3,699 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
