My maytag neptune flashes code nf
When my maytag neptune is on the rinse part of the cycle it stops and starts flashin nf. for the past 2 days i have gotten either this code or one other one that i can't remember.... what is going on. Please help!
  • katupchurch Oct 23, 2008
    just moved in and about every other load it stops and flashes nF. I will try checking the drain hose....
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 28, 2008
Maytag Neptune MAH6500AWW '03 front load nf code it is OVERFILLING won't shut off, water pouring out door! new drain pump last week & checked hoses in front 2 days ago. now this, help?
nf stands for no fill, so this means the washer's water level sensor is defective or plugged with dirt. That is why it is overfilling.
Nov 09, 2016 | Maytag Washing Machines
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
My machine has recently started not completing a full wash cycle and seems to stop before the rinse and spin completion. It also shows a "nf" in the digital readout. any ideas?? Of course I cannot find...
Look carefully at supply water. sometimes hoses are reversed, dad wants to save money and turns off hot, but water is needed to finish rinse cycle....turn on both taps and test again.
Sep 06, 2010 | Maytag Washing Machines
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Oct 25, 2007 | Washing Machines
Washing Machines Logo
786 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
