Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx lights on, hit Start as normal but nothing happens. After a while it goes back from Active to Ready flashing.
Any ideas what can cause this? No water is being drawn, and not noise at all coming from the machine which would indicate any activity.
  • Anonymous Mar 29, 2014
    choose program goes to ready press start button goes to active nothing happens few seconds ready light flashes
  • 130 Answers
First question is does the display light up? If so then does the door lock? If the door is locking then the fuse for the washer that is on the back of the dryer hasn't blown. However if door won't lock, then check the fuse to see if it is open. This is a 208/240 volt washer and the display is the only part that doesn't need 208/240 volts. If fuse if find, then check the water screens in the fill hoses and clean them. This may be more of a control unit issue having failed, Hard to tell without knowing age of unit. Hope this helps
Posted on Jan 28, 2008
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Bosch wfl 2000 problem
it is not doing what it's supposed to do.
power is not routed properly - replace the board
Jun 13, 2008 | Washing Machines
No water comes through Espresione cafe retro coffee machine
seems like these machines need a serious cleaning as that small tube gets plugged rapidly and often
Aug 05, 2015 | Coffee Makers & Espresso Machines
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
Hi, got Kitchen Aid Artisan Espresso Machine. 5y old. Machine just started to brew coffee way to fast. Too much water coming too fast. Normal amount of coffee ready in 5 sec instead of 15-20.... Is this a...
Hi all, got a Artisan 5KPES100 and I'm not getting any water thru' the espresso boiler. Machine is making an occasional noise & sometimes just releasing a bit of steam thru' the espresso boiler, but no water. Have replaced the water pump, but still no water being drawn from the water tank. Hose is NOT kinked & there IS sufficient water in tank. Could it be the solenoid? Can I swap over the solenoids(coils) to check as frothing boiler is still producing water & steam? Any ideas would be magic.
Apr 13, 2011 | KitchenAid Artisan
My Bosch Maxx 900 won't start has power, water and door locks. Light comes on for active mode but nothing happens
Sounds like you have a bad computer board. Is it flashing a error code? You will need a qualified service technician come look at it to find out if that is it could be something else but till you can see it in person and diagnose it with some stuff hard to tell but definitely sounds like the main board is bad and also make sure you let the technician know its a bosch allot of appliance tech's don't work on them Sears does though but there pricey but hope this helps and sorry for the trouble it giving you.
Jan 10, 2011 | Bosch Washing Machines
Thumping noises and a belch when turned on. Will not start.
Judging from your description, I would check your installation and be sure that you have a good water supply. Then check the drain hose. The only things that can cause that are the pump motor and the drain motor. Judging from the parts list, the drain pump fails in those a lot. When the unit is first powered on, the drain pump comes on for a moment as part of the diagnostics. It may have something stuck in it or it may have failed.
Nov 20, 2017 | Bosch SHE4AM02UC 24 in. Built-in...
Bosch Axxis WFL 2060 Front Load Washer Logo
470 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
