Question about DBX DriveRack 480 Processing Unit Home Equalizer
DBX DriveRack PA power failure
My Little brother plugged my driverack PA unit into a 240V power supply (UK) yet it was designed for 120V. since then, it zapped and doesn't work anymore. The unit has no fuse. any ideas on which parts could have a problem and how to go about it?
Thanks
Julius
  • Anonymous Mar 05, 2008
    Recently we purchased a brand new DBX Driverack pa for our group and for the studio also. When I took the unit out of the box and installed it as recommended without the amps hooked or powered up, the LED would light up but no information would display on the screen. This unit is brand new and the factory manual start up will not work either. I have experience the sound of these units in the past, but what a disappointment from the factory. Any technical advise before I send this unit back to DBX.
    Wm.
  • Anonymous Mar 18, 2014
    driverack px dbx greek
    Habit-Forming:
  • 11 Answers
Repair the transformers,,,using a digital voltmeter when both transfrormer are good the measure like 56 ohms, if one is good and the other is bad is gonna measure like 120 ohms , if both are damage it will measure nothing, all this with the switch in its on stage.
If you dont find anyone that can repair the transformers buy them.
Posted on Jan 12, 2009
There is a 500 ma fuse on the internal circuit board at the power supply...check it...
Posted on Sep 28, 2012
It's not a DBX problem, it's a brother problem.
Posted on Mar 04, 2008
  • 152 Answers
You cannot say which part of the system has zapped unless you open it and have a go through the internal structure... even with a circuit idea it is hard to have a clue on which part has zapped...
Posted on Jan 31, 2008
Good day..The common problem in a closed pa system setup is feedback.It limits the capacity of unit to give a higher intensity of volume..With this I just want to ask if DBX Driverack pa+ will work well...
The DBX driveracks work well with about any PA. The only PAs you might encounter a problem with would be one of the newer line array and digital processing PAs. Let your audio person get creative, the presets for multiple PAs are just a guide. If your sound person is confident and is qualified, let him/her experiment and/or rehearse - you'll be amazed at what that system is capable of.
Mar 10, 2011 | DBX Driverack-Pa Eq/Speaker Control System...
DBX Driverack PX "Wizard" not allowing MONO
set it up as mono=common leads together and l,r,leads together,it will see left and right are in use and should load up
Jul 05, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
White screen on the dbx driverack pa? how to fix?
You can adjust the LCD contrast by pressing the Utility button and turning the dial one way or the other. Pressing the Utility button toggles back and forth between LCD contrast and Compressor/Limiter Threshold Meters, so since you can't see anything in the window you may have to press Utility twice, though I think LCD contrast is the first option.
Jan 17, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
When going through the driverack pa setup wizard, where is the "custom" speaker setting?
You should be able to spin the dial all the way to the end of the list of speakers and there you should see custom.
Jul 15, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
No access to driverack 480 with belkin adapter
The Driverack Series all use a Null Modem cable for the connection to the Serial Port. A standard serial cable or female to female lead will not work, as the wiring has to be of the Null Modem type. A suitable lead should be available from your local PC supplier, failing that DBX can supply you with one also.
Hope that helps.
Jay
Feb 04, 2009 | DBX DriveRack 480 Processing Unit Home...
We have a dbx Driverack PA unit with a Crown CDi1000 amp in our church. Recently, we starting having problems with the output to our main speakers dropping out. We found (by accident) that if we unplugged...
Check the speaker wires coming out of your amp. Chances are you have a problem with a speaker wire and this is just a coincidence. I say this because the same thing happened to me during a live show and I about had a heart attack. We lost the front of house for about 15 minutes while I tried to troubleshoot the Driverack, the board, and everything but the speakers and speaker wires. The cables were a recent purchase and were premium grade with light wear so I mistakenly ruled them out. It was intermittant so it took me a while to figure out. Now I understand that that's the weakest link in the chain and from now on I start there and work backward through the chain (that is, if all sound is cutting out).
Do you use banana plugs (two metal pegs sticking out of a plastic rectagle) coming out of the back of your amp? There are little screws inside the holes on the back of the banana plugs. Those can vibrate loose, especially if they're just factory tight. Get a little standard screwdriver and tighten them down. That will probably solve your problem.
Okay, wait a minute -- could be one more thing. You mention that the loud popping can be heard. Do you have any gates turned on? Most compressors have gates. Check your compressors to see if you have your gates turned up too high. A gate set too high would allow the loud pop to go through to the PA but would cut off everything low to mid-volume.
I guess you can see that I don't think it's a problem with the Driverack. I don't work for dbx or anything, I just think these other things are far more likely than a problem with the unit.
Jan 02, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
DBX DriveRack 480 Processing Unit Home Equalizer Logo
875 people viewed this question
Top DBX Audio Players & Recorders Experts
Chickenwatt
Level 1 Expert
Vito Vacirca Jr.
Themcramers
Level 1 Expert
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
