Question about Roper 24 in. RUD4000M Built-in Dishwasher
Copier - canon np6010
I changed the cartrige of powder and now the copies are all very dark and not getting lighter. The regular adjustment feature doesn't help very much. What can I do? Canon-Keret won't help. Carole
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
To stop this Bay chip reset software from ebay or another place for Canon
http://cgi.ebay.in/ws/eBayISAPI.dll?ViewItem&item=110521860863
its working and very low cost at just 2 dollers and 99 rupies
Posted on Apr 19, 2010
How do I adjust the settings so copies are lighter when printed?
go into te computer and open the printer section
there is a settings section that may have a toner setting
Oct 21, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
I have a D320 Image Class
dear it is problem copy emage plese setup copy exproser
or printer set up
  1. edit toner save mode off
Jul 09, 2009 | Canon imageCLASS D320 Digital Copier
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
I want to darken copys on my canon pc850
it seems you used the cartridge upto 3 times usage. you may need to change the drum.
Feb 17, 2009 | Office Equipment & Supplies
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
COPIES TOO DARK ON CANON COPIER NP6035
First of all did you clean the optic? How about did you replace all of the corona wires? Also, did you clean the scanning lamp as well? Also when you had fitted the new drum, did you use a brand new one or a different one, did you clean the drum with rubbing alc. If all that was done, do a "AE" adjustment in service mode using white paper on the copy board glass. Also, go to the addictional funcation mode and go to expossure adjustment and make it lighter. Or as a last effort adjust the corona hieghts of the primary corona wires. Good Luck...
May 01, 2008 | Canon NP 6050 Copier
Canon 330s Copier with Dark printouts
How dark is it??
canon is sensitive to dust,
turn off machicne take off top copy glass move scanning glass and wipe with a clean towel.
try adjusting the dark and light does it change? if it comes out better on light then the drum is the problem. ( getting old)
Nov 29, 2007 | Canon imageRUNNER 400S Copier
Dishwashers Logo
105 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
