Hai sir i need to step by step to configure of DNS linux version 5
    Genius:
  • 1,665 Answers
Try this: may help you
http://tldp.org/LDP/lame/LAME/linux-admin-made-easy/domain-name-server.html
Note: Note: Red Hat versions 5.1 and earlier used the BIND 4.x package, which used a slightly different format for its configuration file. BIND 8.x offers more functionality over that offered by BIND 4.x, and as 4.x is no longer being developed, you should probably consider upgrading your BIND package to the latest version. Simply install the BIND RPM package (see Section 10.1 for details on using the RPM utility), then convert your configuration file to the new format.
Posted on Jan 28, 2008
How i configure domainjoin and clientjoin to server linux5.3 Plz send article.
Hi Biswajit_183,
I found that link when i needed to setup DNS(Domain Name Server) & Client Configuration Setting. Please Follow that link and let me know if you need any help.
http://www.cyberciti.biz/tips/linux-how-to-setup-as-dns-client.html
Thanks
Jan 12, 2011 | Computers & Internet
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
I cant get acces to my Modem or Wifi using "192.168.0.1? Help
May be 192.168.0.1 is not the address to configure that router.
Start, Run, CMD to open a command prompt:
Type the following command:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
example results.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adamprince>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Adamprinces
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-0A-48-08-24-52
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 202.27.184.3
Lease Obtained. . . . . . . . . . : Tuesday, 24 August 2010 5:35:33 p.m.
Lease Expires . . . . . . . . . . : Wednesday, 25 August 2010 5:35:33 p.m.
____________________________________________________
The address to configure that router is 192.168.1.254
Aug 26, 2010 | Computers & Internet
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    Dear sir, How can i configure my domain
    First and formost, you need following check list before configuration
    1) System partition must be formatted as NTFS.
    2) Machine must have static IP address.
    3) DNS installed
    Then run a dcpromo command and configure domain.
    Jun 10, 2009 | Microsoft Windows Server Standard 2003 for...
    DNS Name resolution Between private & Public network.
    You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
    Mar 24, 2009 | Microsoft Computers & Internet
    Configuration of DNS with LINUX
    Which version of linux u plannedto install?
    Sep 22, 2008 | Computers & Internet
    DNS
    firwstu important for
    dns domain name services
    name to ip\
    ip to name
    and createto host id
    and pointer.
    create todomain name.
    bye
    Jun 04, 2008 | Microsoft Windows Server Standard 2003 for...
    Nvidia Quadro4 (128MB RAM) driver required for linux 2.4.20.18.7
    hi there..
    here is the link for your Quadro 4 Graphics for linux 32 Bit
    To download and install the drivers, follow the steps below:
    STEP 1: Review the NVIDIA Software License.
    You will need to accept this license prior to downloading any files.
    STEP 2: Download the Driver File
    Download - NVIDIA-Linux-x86-96.43.05-pkg1.run
    SuSE users: please read the SuSE NVIDIA Installer HOWTO before downloading the driver.
    STEP 3: Install
    Type "sh NVIDIA-Linux-x86-96.43.05-pkg1.run" to install the driver. NVIDIA now provides a utility to assist you with configuration of your X config file. Please see Chapter 3 of the README or run 'man nvidia-xconfig' for details on usage. Instructions for those wishing to edit their X config file by hand can also be found in the README.
    here is the link for your Quadro 4 Graphics for linux 64 Bit
    Download - NVIDIA-Linux-x86_64-1.0-9639-pkg2.run
    STEP 3: Install
    Type "sh NVIDIA-Linux-x86_64-1.0-9639-pkg2.run" to install the driver, then edit your X config file as appropriate. If you are using a Linux 2.6 based system, type "modprobe -q agpgart", first. See the text README for more detailed instructions.
    All the Best.
    Was this solution helpful? Show your Appreciation by rating it:
    Feb 19, 2008 | Nvidia Quadro NVS 280 (64 MB) Graphic Card
    Computers & Internet Logo
    89 people viewed this question
    David Payne
    David Payne
