Question about RIM BlackBerry Pearl 8100
HP Pocket Pc won't turn on
The last time I used my pocket pc the touch screen kept bringing the mouse to the corner. Then the top tool bar started to disappear. Next thing you know it turns off and wont come back on.
    Problem Solver:
  • 9 Answers
I assume you have already tried a reset with the stylus in the hole in the side of the unit, if not try it.
if you want to try to hard reset. (this will reset to the settings it came from the store with). Try one of these two techniques.
1. hold the power button while inserting the stylus into the reset hold until the screen flashes.
2. hold the power, calendar, and email button while pushing the stylus in the side/bottom of the unit until it resets.
Posted on Jan 28, 2008
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
I can not get in to my pocket pc hp ipag on start . after turning it on a small lock appears on the top left and after a while a screen will appear asking me for a password which I have forgotten. so it's...
you can try a hard reset(hold the 2 corner buttons down then using stylus insert in the small hole on the back for soft reset) this will restore factory settings. if you have sync folder on your computer you should be able to retreive contacts, pics, etc. hope this helps.
Sep 21, 2009 | HP iPAQ RX1955 Pocket PC
Pocket PC 2003 Pro unable to align screen
the touch screen plug on the motherboard is disconnected
Sep 06, 2009 | HP Computers & Internet
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
Get to Start menu
I have same problem but found a work-around. I have found that 2 SD cards kept in the pockets in the flip over cover of my leather case has caused scuffing to the touch screen and the screen will now not align properly. In the alignmet utility I have to tap the centre of the alignment cross in the middle and 2 top positions and tap about 3mm above the cross in the bottom 2 positions (portrait format). This means of course that the bottom of the screen is out of alignment and I have to tap high at the bottom of the screen but I have got used to it. Not great, I know, but its better than nothing.
Oct 13, 2008 | HP iPAQ HX4700 Pocket PC
Locked up HP Ipaq Pocket PC
find your manual and use the default password since the unit had been reset.
Aug 18, 2008 | HP iPAQ H1910 Pocket PC
Fixed white block on the top title bar
This is clearly a hardware fault in the actual lcd display or the connector to the mainboard. the stylus function are controlled by the touchpad, it is mounted separated from the actual lcd display (on top of it) and connected with another set of wires to the mainboard. Most probably your problem can't be solved. However, try to take it to a service to have it checked, especially the connectors between the lcd and mainboard.
Dec 27, 2006 | ViewSonic V37 Pocket PC
Screen saver
go to Start > PROGRAMS > Dockware. Now click on the top left hand corner of screen. Click on 'Setup' to uncheck the box to Automatically start Dockware.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
To synchronize your Toshiba Pocket PC (e570, e310, e740) with your notebook over a Infrared connection, please follow the below instructions: Ensure that the Microsoft program ActiveSync is installed on your notebook Ensure that the infrared port of the notebook is enabled Line up your Pocket PC IR lens with the IR-lens of the notebook On your Pocket PC, please on to "Start" and select for the menu "ActiveSync" Tap with Pocket PC pen on "Tools" in the left lower corner and select "Connect via IR.." The synchonisation will start automatically. Simple follow the on screen instruction to complete the process Please see below:
Sep 07, 2005 | Toshiba e310 Pocket PC
RIM BlackBerry  Pearl  8100 Logo
41 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
