Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Sound problem When I connect asound device be speaker or headphone sound is not played,and I also not that the hardware doesnot appear on the task bar
  • eagledvd Jan 28, 2008
    A friend of mine has the same problem: after installing WIN XP, the system does not recognise the sound & VGA???
  • 109 Answers
Make sure the sound/VGA drivers are installed:
Do the following:
1. Go to Start > Run and type: devmgmt.msc than and hit Enter.
2. A screen pops up showing all your devices. (Device Management)
3. Check if your soundcard has a yellow questionmark or a red cross next to it.
In case of question mark:
If your PC is from a brand such as HP or so visit it's vendor's website. When the sound is onboard they should have your card. If you have a sound/vga card that is in an expansion slot visit the website of it's manufacturer. Locate your card there and download drivers (+ additional software). The drivers are usually in the Downloads or Support sections.
In case of red error:
Make sure the hardware is connected properly. If you are certain it is and when it still doesn't work try other drivers (see above). If it still doesn't work, it might not be supported or broken.
I hope this helps you out. Please rate.
Posted on Jan 28, 2008
No sound on computer
hi nina.this could be a lot of reasons why you have no sound.
Update the audio driver using Device Manager as follows:
  1. Connect to the Internet.
  2. Click Start , and type device manager into the Start Search field. ...
  3. Double-click Sound, video and game controllers. ...
  4. Right-click the name of the audio device listed under Sound, video and game controllers.
  5. Select Update Driver Software...
  6. If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones. ... Under Hardware and Sound, click Troubleshoot audio playback.
  7. If you hear sound through the headphones, the sound hardware on the computer is working, and the issue is probably related to the speakers or speaker cables. Disconnect the headphones and reconnect the speakers. When done, test again forsound using the same steps as above with the volume control slider.
  8. If you are running Microsoft Windows, make sure the speaker setup is correct by following the steps below. Select Hardware and sound or just Sound in the Control Panel window. In Windows XP and older, click Manage audio devices under Sound. On the Playback tab, select your speakers and click the Configure button..
  9. or go to this link if you need mote help.
No sound on computer Google Search
Nov 05, 2017 | Computers & Internet
No Audio/Sound
The computer is in amuted state
There are a few ways this can be fixed; one is to press the mute buttonon your keyboard if there is one. The other way is to go onto control panel,select "hardware and sound" then select sound, click your chosenaudio device , chose properties then chose the "levels" tab and makesure the audio output is not in a muted state if so click the speaker button toturn it off mute.
The headphones or specks are not connected to the pc or have become unattached
Make sure the headphones/specks lead is plugged into the correct portwhether being a USB port or audio port depending on the device. This may be inthe back/front of a computer, the monitor, keyboard or external audio adapter.
  • Green is for speakers
  • Blue is Line In
  • Pink is Microphone
You have selected a certain application to be muted while others are not muted
To check if an application has been muted, click on the little arrow onthe windows start up bar by the clock normally, and select speakers. You willthen get a new window showing any application requiring audio. If one has beenmuted the speaker below it will have a red mark on it, click the speaker buttonand it will no longer be muted.
Your sound device is not selected
To change the sound device, click on the little arrow on the windowsstart up bar by the clock normally, and select speakers. A new window willdisplay with a column saying device, there will be a drop down menu under apicture of a speaker where you can change the speaker's audio device.
Update audio driver
Your audio device may need a driver update, the updates can normally befound
On manufacture websites (Look at this page for more details
Try different speakers
Try different speaker/headphones to see if your speakers are broke.
Check the sound driver is installed
Go to control panel and find device manger this is normally under thesystems area. Click on "sound, video and game controllers" tab, ifthe audio hardware device is there, then you know the computer is aware of theaudio hardware driver however if it has a yellow mark next to the device,
This would indicate that the computer is aware of the driver however it doesnot have the correct drivers for it to work. This is where you are required to lookfor drivers sometime off a website or a CD
on May 08, 2011 | Computers & Internet
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
Aug 05, 2013 | Acer Computers & Internet
My sony vaio has no sound coming from the speakers i have tried to uninstall and install the drivers but nothing is working the sound appears to be on as media player has no problem playing anything. my...
attempt to connect external speakers or headphones. if thet work, your internal speakers are the problem and needs replacing. you may also at least check the sound properties and under playback section, make sure the correct playback device is selected. Normally, it should be the speaker/headphone audio device unless you use digital playvack device.
Dec 31, 2010 | Audio Players & Recorders
Vinyl ac'97 sound No sound!
please check if the Audio cable is on the right port.also check the Volume Level weather its in Mute.Also Check if ur Speaker si working or Power to Check Weather the Speaker is Working Just use a Different Power Source like MP3 player or Ipod.if no Sound frm the Speaker then it Time to getr new Speaker.Adios
May 16, 2009 | Computers & Internet
Audio driver jack & sound control not working properly
This means that their is a sound indicator but no sound comes out from your headphone.
I want you to double click the speaker icon found at the bottom of your task bar, along with the time and other icon.
A dialog box will appear, un-check all the option found on that window, add also some option by clicking the file options.
Thanks again.
Nov 05, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Logitech microphone stuffed up my Computer Speakers!
go to sound icon in bottom task bar, double click on it,go to options,then properties,then click RECORDING,make sure you have a tick in MIC,then go to back to sound icon in bottom task bar,and adjust mic settings to suit
Sep 19, 2008 | Logitech (980240-0403) Microphone
ThinkPad R40 with no sound
Oct 04, 2007 | IBM ThinkPad R40 2722 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
