Question about Samsung LN-S4041D 40 in. LCD HDTV
Samsung 40in tv
My tv changes channels by it self.
  • jorg502 Dec 28, 2009
    My TV changes channels by it-self.
  • Samsung Master
  • 610 Answers
Either the control panel board or the main board has a problem.probably channel change botton on control panel is stuck or shorted.
Posted on Dec 28, 2009
SOURCE:
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
Is a Insigna TV, it turns on by it self and starts changeing channels and I can't stop it I have to unplug it.
the problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Televison & Video
This problem never happened before , We on the tv and the channels keep changing by it self . We are not touching any buttons and we even tried offing the tv and switching the power off . Each time we on...
As a test, block its (or the cable Box's) remote infrared sensor so even you can't change the channels with a remote. Then watch and wait. If it keeps happening, you have a poltergeist or a defective unit.
If not, something out 'there' is emitting infrared signals that the unit interprets as channel commands. Find the remote someone is sitting on or that guy across the street who's aiming at your TV with HIS remote.
Mar 06, 2011 | JVC Audio Players & Recorders
Changes channel by its self it goes crazy
You have ONE of two possibilities....on the Front panel buttons, you MIGHT have a stuck button or leaky button....
I suspect that if ALL it does is change channels...it would be a channel UP or DOWN button stuck....yes, it can fire up the tv too....But it will dedicate itself to doing only ONE function.
IF you have multiple operations, like changing channels, menu appearing, volume changing....then the MOST likely problem is actually the microprocessor causing the problem....BUT it is STILL possible to have SEVERAL buttons stuck....rare, but possible.
And unfortunately unplugging it won't even help in any of these possibilities....
You have to start with pressing each and every button one at a time and see if the problem stops afterwards....
IF it doesn't, then the next step is to measure the resistance across each button....they should read Infinite ohms.
If any measure lower, the button should be removed and see if the TV acts normally...
IF the buttons are located on a separate board with a plug that can be disconnected, you can just disconnect that while it's acting up and see if the problem disappears.....
If it still misbehaves after this, you NEED to get it to a TV tech for further analysis with a scope.....
Jul 08, 2009 | LG 47 in. Flat-Panel LCD HDTV
Channel changing Problem
when you hit auto channel the tv  start to check the signal incoming
and put in memory the good signal - i think your tv is functioning
you have to use the channel on manual for   put in memoty what
you need- delfo
Mar 20, 2008 | RCA F32718 32" TV
TV turns on by it self then constantly changes channel
the controler brain has to be replaced main bord
Feb 03, 2008 | Televison & Video
My tv changes channel by it self
I have the same problem, anyone with a solution
Oct 25, 2007 | RCA P52926 52" Rear Projection Television
Tv is possesed
there is a broken solder joint or trace somewhere on the circuit board. VERY difficult to find.
Jun 06, 2007 | RCA 27V520T 27" TV
Samsung LN-S4041D 40 in. LCD HDTV Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
