Question about NEC MultiSync MT1020 Multimedia Projector
Vertical line the picture is good except for a semi transparent line about 3/4 inch on the right side of the screen,i know you cant adjust the lcds on this model so i traded lcd bracket from an mt820 that has screw adjustments for up down/right left.The line did'nt go away but the lcd's are aligned better.is their another adjustment im missing to correct what seems to be overlap
  • 1 more comment
  • lanzzata Feb 02, 2008
    i am using video cable,i also get a ghost image of the menu.when on vga also get line and ghost image of icons on left,but as i said i still get a clear picture,i have noticed this on other nec mt's
    the only reset is on the remote,no change after reset..
    this is an older unit,their are no adjustments in menu,i believe the lcd's or lenses are misaligned and as i said it's a common problem with this unit..
    Genius:
  • 1,067 Answers
What cables are uusing for tis 15pin vga in or hdmi ?
Posted on Feb 02, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 02, 2008
    ya might be that light engine did u try a reset
  • nick helpap
    factory reset in menu options sum have calbarting that light engine out of whack thats what u would have to cheak out
  • nick helpap
    ya that comes from light engine well sell for parts on ebay unless u wann try to repair that light engine benq makes the best
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Vertical lines in my laptop screen
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
NEC MultiSync MT1020 Multimedia Projector Logo
178 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
