Question about ASUS P4V8X-X Motherboard
Sata hard disk drive on asus p4v8x-x motherboard
Hi! I attached my 80GB hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive. Is my board not capable of handling Sata drives?
  • 7 more comments
  • junie0607 Jan 28, 2008
    I am using windows xp sp2. Sata hard disk drive is not detected on my bios set up
  • junie0607 Feb 07, 2008
    My heartfelt gratitude to castatroy for unselfishly extending his help. I tried your suggestion and also consider other suggestions. I tried ciwaruga008's suggestion by installing via sata/raid drivers but have it done during OS installation and it works. To ciwaruga008, you are an answered prayer. Thank you guys for the help. God Bless and more power!
  • Anonymous Apr 12, 2008
    Hi, I to have a sata problem. I have a seagate Barracuda 160gb. The bios on startup see the hdd but when you attempt to install xp pro and get past the aggreement it says there is no hdd attached. I have flashed the bios with no effect. I feel like chucking the mb in the bin. keller.
  • Anonymous May 29, 2008
    pls give sata red drivers
  • ngema Jul 27, 2008
    hi i have a problem of 500gig sata hdd.my asus m/b p4v800-x did not ditect it.
  • febsens Oct 28, 2008
    I attached my 250GB hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message
    cant initiate the new hard drive , bios does not installed .
  • Anonymous Dec 02, 2008
    Yes, my HDD Sata not detected on my ASUS P4V8X-X Motherboard, Why
  • Anonymous May 22, 2009
    bios hdd sata unknown
  • castatroy May 11, 2010
    Does your operating system not detect the harddrive or is is no being detected by the Mboard? plug in your hard drive and turn on your computer, check in the bios setup whether the mboard does detect the HDD if it does then the problem is with your operating system. What Operating System are you using anyway? let me know and I will be able to help you.
    New Friend:
I faced the same problem with this mobo...I needed a SATA HDD for data storage, while the system was on a PATA HDD. The drive was a WDC 1600 AAJS, a SATA2 compatible one and to make it work, I had to jumper it down to SATA 1. (5-6 pins as I remember) I also set my BIOS the way it was described above. (ACPI 2-disable, APIC-disable) Then at restart, BIOS recognized and listed it. Ubuntu 9.04 and 9.10 works with it seamlessly.
As I ran through several sites, I saw that old power supplies can also cause similar problem,. If you connect a SATA drive with 3.3V needs, since old PSUs can feed only with molex-SATA power converter cable and that does not provide 3.3V.
mobo:P4V8X-X, BIOS ver.:1008
Posted on Nov 01, 2009
I MANAGED TO FIX THIS ANNOYING PROBLEM BY REPLACING THE JUMPERS OF MY HDD FROM CURRENT POSITION TO NEXT ONE.
I THINK I PUT IT ON CABLE SELECT AS THERE IS NO SIGN IN MY HDD.
I USED 160GB WD H.D 7200
Posted on Mar 22, 2009
I think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
Posted on Feb 01, 2008
    Scholar:
  • 119 Answers
Okay. If your board has SATA connection slots it most definitely is SATA compatible. Check on your motherboard how many SATA slots you have, make sure that your HDD is connected to on the Mboard with any other drive in a numerical order (on the Mboard right next to the SATA slot it should read SATA 1 or SATA 2 ........). If that does not work plug is you HDD drive loosely so that when you switch on your computer you can listen to the HDD. should it emit a humming sound, meaning its powering up the problem could lie with your SATA slot or SATA Data Cable, try a different DATA cable if this does not work try blowing air into the SATA slot on the Mboard, If no luck then maybe the slot is burnt out or malfuntioning. Should you not hear a humming sound coming from your HDD then its either faulty or the there is no power going to it. try to alternate between the cable of your power supply. Try these and Please let me know how you go.
Regards
Posted on Jan 29, 2008
  • ASUS Master
  • 2,010 Answers
What most People forget is direct to handle with the latest bios flash update , because of the marketing technical difference in the build time of mobo build revisions like a suggestion INTEL or ECS and more brands have build different revisions like rev 1.0 or 1.1 but the first way is to look also for the serialnumber on the motherboard before because of some are build for new support for a new model processor and do not forget to look for the right build revision before flashing the bios and always make shure the bios is in defaultmode (for some older bios brands its neccesary) when flash it. The motherboards coming in the shops but the software and bios is not allways ready , Creative labs is a company that have made in early 2000 cams with that problem that people without internet , cannot working with some hardware combinations without flashing firmwares or bios.
In these days 2016 its much better but sometimes there are firmware problems can be by SSD or motherboard bios to support the later build processors and sata for AHCI or IDE native mode.
Posted on Jul 18, 2016
I have problem same with my motherboard asus p4v8x-x can't found hhd sata seagate sata st 38215as all your solution i try but not run why and why?
Posted on Jul 16, 2009
Just to verify, I am running xp pro sp3. prior to getting the sata hdd running i installed VIA Raid controller 3149 and VIA Bus Master IDE Controller. I then cloned the sata, disconnected the ide hdd, connected the sata hdd restarted and it worked. i also jumpered the sata hdd to ensure it ran at a slower speed because (i read this somewhere on the net) this board does have sata but it runs at i think 150 and not the full sata speed. anyway i still touch wood when i hit the start button and its still running well.
Posted on Jun 16, 2008
Send an answer of my question?
Posted on Jun 14, 2008
  • 407 Answers
I suspect your board does sata drives.instead check for a drive with ide connector..
Posted on Jan 28, 2008
Hi! I attached my 80GB hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive. Is my board not capable of handling Sata drives?. Thank You
Posted on Sep 17, 2008
This may help - To some I may be a complete novice and I will admit I am still learning by my mistakes. I made sure that I had ALL the latest drivers and bios downloads possible - still hdd was not recognized by windows on its own. I also had a ide hdd attached and my sata hdd was seen as just a second drive with the same volume as the ide hdd. My final try before the M/B went in the bin was to go to the hdd's website (in my case Seagate) where i downloaded a Seagate Disc Wizard. I then cloned from my ide hdd unto the sata hdd and like magic (sorry for the pun) the sata hdd was recognized in its full glory. It's now running just the way it should and I am a very happy person. I do hope this will help some one else. Cheers.
Posted on Apr 16, 2008
6ya staff
SOURCE:
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
I have a asus p4v8x-x motherboard which earlier had an IDE connected Dvd burner but now i want to install a SATA burner i have connected the drive on my SATA port but my computer does not show identify it
Hi, you can download a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4V8X-X&p=1&s=15
Please select your operating system.
Select manual and click on global for download.
Unzip the file before you can read it.
Maybe its just a setting in the bios that does that.
Aug 28, 2011 | ASUS P4V8X-X Motherboard
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
HP dc5100MT motherboard
Based on what I have read about the HPdc5100MT motherboard it only supports SATA hard disk. Not sure how you are able to use a 80GB IDE.
See configurations from HP at this website. All hard drives are mentioned as SATA.
Jun 06, 2010 | HP Compaq dc5100 Microtower PC Desktop
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. [email protected]
Dec 13, 2009 | ASUS K8S-MX Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
Jan 20, 2009 | Computers & Internet
ASUS P4V8X-X Motherboard Logo
8,741 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
