Question about Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
I just bought a new epson lx300+ii and i plugged it with a serial cable to my fujitsu PC. When I print using a DOS based program, at first it printed a few delayed line and then it became hang. I plug back my old elpson lx300+ and it worked smoothly. I have set all setting and compare the setting (baud rate, etc) from the epson lx300+ii and the epson lx300, it's all same settings. Printing using windows has no problem, but I need it to print using a DOS based program. Have you encountered similar problems? Is there any explanation and solution? Thanks.
  • aiktwo Feb 02, 2008
    Sorry Benson, but I'm not using XP, I'm using a DOS (MS-DOS) based program, and usually there's no printer driver for it, we just plug it, and it works :)
    Actually I've tried to make my own serial cable, and it seems work, but I'm not sure if it function properly, because I connected a loopback from the computer back to itself, so no error message can be sent by the printer.
    But I'm still curious what's the different between epson LX 300+ii and LX-300+ that can cause such a fatal disfunction? Perhaps there's someone know something? :)
    Thanks anyway, Benson, Keep up the good work.
  • 3 Answers
Use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Posted on Feb 02, 2009
I need how to change the setup, could u plz help me
Posted on Feb 12, 2010
Could you please give me the settings for epson lx-300 ( baud rate, etc. )
My epson lx -300 in connect to COM4 but doesn't print I cheked the setting but I don't know if they are correct.
Thank for your help
Posted on Mar 24, 2008
  • 3 Answers
Just a couple of questions that might help your problem.
- Have you already installed the driver of your lx-300+ ii?
- Are you using that driver for your lx-300+ ii printer?
XP as far as i know does not have an Epson lx-300+ ii driver.
And yes, it only have the lx-300 & lx-300+.
Using backward software (i mean, using the lx-300+ driver
for your lx-300+ ii) is possible but not advisable.
benson
Posted on Jan 29, 2008
I cannot print the endless paper
The Epson LX300 has a paper release lever which should be set
; forward for continuous paper printing and
: back for single sheets.
Oct 03, 2011 | Epson LX-300+ II Matrix Printer
Epson printer lx300+ii printer, if i print a document atometicaly pause
Hello!
Make sure that there is no paper jam in your feeder. You have to clean the feeders if there is any dust insde of it.
Regards,
fossildude
Nov 22, 2010 | Epson LX-300+ II Matrix Printer
Lx300+II commucation error
That's not adequate info for us to help. What is the communication error message and when does it occur? How is it connected to the pc, ie: parallel port? What BIOS setting do you have the parallel port set to? ie: standard, enhanced, other? Are you using a good quality printer cable, ie: high compliance IEEE? Have you tried another cable? Has the printer ever worked? What is your OS?
You should provide details when asking for help!
Sep 09, 2010 | Epson LX-300+ II Matrix Printer
Instal printer lx 300 to usb, can,t print?
To make sure that printer is detected then do following things.
Before going for deep trouble shooting please make sure following things:
Ensure that USB cable is Plugged properly on both side.
You can swap USB cable to other USB Port.
Ensure that Printer is ONLINE and Paper is loaded.
If above mentioned things are propter then follow below mentioned steps.
1. Keep The printer ON and remove Usb cable and re plug in Computer.
2. Check on System Tray (near Clock) check that Printer is Detected. or you can check this by Checking in Device Manager. You can open Device Manager by Right Clicking My Computer>> Property>> Device Manager>> Hardware Tab.
3. If device found detected then Open "Printer and Faxes" from Control Panel.
4. Right Click your Installed Printer lx300 icon and click on property.
5. Click on "Port" and ensure that Check Mark Should be on "USB00..xx" not on LPT.
6. If Check Mark is on USB00..xx"" then try to give Test Page.
7. If test page is not printing then try by complete removal of Printer Driver and Re-Install It.
Mar 28, 2010 | Epson LX-300+ II Matrix Printer
My problem is im using a laptop, in my printing is EPSON LX300, what would do to make it run?
You need extra USB to Parallel device.
If you bought LX300 without USB interface you need this device... The USB port will be attached to your laptop and the Parallel port will attached on your printer parallel interface.
Oct 23, 2009 | Computers & Internet
Printing problem
Check the communication cable , disconnect the cable from both the end and then reconnect the cable properly after that print not coming out then uninstall the driver and restart the system and after restarting the system then reinstall the driver properly and then restart the system again after restart check , if after doing all these things if print not coming then change the communication cable with a new one and after changing then check
Jun 06, 2009 | Epson LX-300+ II Matrix Printer
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
Feb 04, 2009 | Epson LX-300+ II Matrix Printer
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
May 26, 2007 | Epson LX-300 Matrix Printer
Epson LX-300+ II Matrix Printer Logo
1,862 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
