Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Intermittent Fault, going into standby and won't return.
Some days the tv works, others it will not turn on at all, it just stays in standby. but when it doesn't work there is a high pitched sound coming from either the transformer on the power board or the largest capaciter. the sound is not constant, sounds to me like a capacitor charging and then venting. cannot see any bulging or disscoloration of any cpacitors or components
Cheers
Chris
  • the_hamel Jan 30, 2008
    Before i shelled out for a new board from samsung i checked all the earth connections on all the boards, ie took them out and made sure they were clean and stuff, and hey presto it works fine now. must have been a dry joint.
    Cheers
I think you should replace your power board.
Posted on Jan 28, 2008
Sony bravia problems....intermittent fault. Colour turns psychedelic. Looks like TV is "on acid"!! Sometimes TV can run normally for several hours before the colour fault occurs.
You have a defective T-Con board. The small board near the top center of tv. Can not give you the part number without knowing your TV model. Depending on model $50-120 for part.
Apr 16, 2014 | Televison & Video
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you:
Flyback Transformer
must have supervision of a qualified service technician
Sep 23, 2012 | RCA 20F512T 20" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have a Samsung 3D TV (46C7000).I have developed an intermittent sound fault. When the TV is switched on I get a high pitched Tone emitting from the TV over the sound of the broadcat program. Sound is...
The tv have a problems in it power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.Power supply board have some bad high voltages transformers.That why ur tv even getting a high pitched sound even the tv it is off and tv it is not even on,and tv it is on standby mode only.
Sep 22, 2011 | Samsung Televison & Video
My mums orion TB32 RN10DA gets lines across screen then conks out, after leaving for a while it will go back on, then repeat this at certain intervals. it has been to a tv repair guy who left it switched...
Get some Freeze spray, next time it faults, start spraying components, the one that when sprayed, returns the set to normal, well there is your "Faulty" but, now you must find out WHY that component "Heated Up" did it spontaneously fail? Or is some other component "Take it out", you must then go to the Power Supply, and check all Voltages. You will need a service manual to do that. Intermittent faults are a vane to us Engineers, they are the WORST, fault to sort of have,.. It is always better, if a "Fault" is "Hard On" at least you have a point to work from, but intermittent ones are real hard...I have been doing this for over 30 years and some still stump me, and I am still learning..
Mar 28, 2010 | Orion1934 19" TV
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
203 people viewed this question
Jerry Greenberg
Jerry Greenberg
