I have an Amana acf3325a gas range. the oven will not work in the bake mode. it will work in broil (hanve not tested cleaning mode). any help would be much appreciated.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace. Part number is 74008064.
Keep in mind, ignitors are fragile.
