Question about Yamaha P4500 Power Amplifier 2-Channel
Yamaha P4500 service manual
Anyone know where I can source a service manual for this amp? I have tried most of the manual sites and they offer user manuals but not service manuals.
  • stage-audio Mar 10, 2008
    Managed to obtain a manual from Yamaha, who turned out to be very helpful. Had to pay of course, but at least all parts are available through them this way.
    Novelist:
  • 236 Answers
One thing for sure Yamaha will not turn their back on their customers for support. What they normally say is that you contact your nearest service center for assistance. But you know you have a very good chance of getting a copy of the service manual since this is a very old model. i have the same amp being used in our church and yamaha service Japan has sent me by postal mail. technology nowadays is much different so maybe they can even send you in pdf format.
Write them by postal mail :
Yamaha Corporation
A/V PA Service Department
10-1, Nakazawa-cho, Hamamatsu, 430-8650 Japan.
simply tell them you need the manual and you are doing the servicing on your own. No one in your area can help you with it.
anyway, what is wrong with your P4500, it's a good amp but sensitive. very good design, hard to troubleshoot if you're not familiar with Yamaha amps. The main parts you can not replace buying from a local store though you may get the same part numbers specially power/driver transistors. it always comes in complementary pair critically matched by tthe factory. i tell you don't get the replacement anywere but Yamaha only. Yamaha have made to order power transistors tailor made for this Amp. you'll find the same transistor number outside but when you plug the unit, it wont last and worst it bursts !!! be carefull. Very hard to scan a copy of manual for you, but if you dont get a reply from Japan you can email me and we'll try to find a way to send you a soft copy.
Reden (redrivera0314@yahoo.com)
Yamaha service from Saudi Arabia 1996-2001
Posted on Mar 19, 2008
    Genius:
  • 1,175 Answers
I managed to get a free PD2500 schematic online . the amp I was fixing turned out to need some solder reflow on the PCB ( on the channel with the problem)
Works like a charm.
If that model has the tubular cooling fan I suggest taking it out and cleaning/lubing it.
Posted on Feb 08, 2008
  • Scott Frye
    Scott Frye Mar 10, 2008
    another site "off-shore" I think
    manuals-in-pdf.com
    Way cheap
    Also, some mfgs will give schematics out for free. QSC and Peavey to name a couple.
  • 36 Answers
Hi!
let me tell you something. don't vote me unless you think my point of views bingo's and give me "fixya" rating.
i m pretty sure that manufacturers do no provide service hand manuls to anyone except to their "authorized" agents/dealers. In very odd cases they sell manuals as part of accessories. Unless you are an insider or unless some how some older models may have copies slipped out. my answer is "no chance".
pc-cook
Posted on Jan 28, 2008
  • Clement Tam Jan 28, 2008
    ps:
    i found out that it has slipped out, for sale at manualcenter.com. $15.
    pc-cook
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha p4500 in protection mode
The manual says the heat sink is too hot or an unacceptable DC voltage was sensed going out.
http://www.retrevo.com/support/Yamaha-P4500-Amps-manual/id/962bh144/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Oct 07, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Hi We have an Allen & Heath Mixing Desk connected to two Yamaha P4500 audio amplifiers (via graphic EQ and compressor/limiter) which power the 4 main and 4 side speakers in our church. We now want to...
'Splitting' leads is never the best way to distribute a signal. The best solution is to use the parallel inputs of the Yamahas to chain them together: mixer to amp1, amp1 to amp2, amp 2 to the Cloud. You should only need to use one input on the Cloud to drive all the channels, using the input switches at the rear.
Let me know if you need any clarification on this.
Sep 21, 2011 | Yamaha P4500 Power Amplifier 2-Channel
YAMAHA p4500 daigrem
This is a service manual of your device and it can be downloaded for free and I hope it is suitable for you (included schematic diagram). Go to this web site:
http://elektrotanya.com/yamaha_p4500.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading so please be patient.
Thanks.
gylacz
Aug 19, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
One channel does not receive signal as shown by the led.oudtput stage is perfect the amp is a Yamaha P4500 poer amp
Try reverse connecting the channels, in order to locate where is the problem; at the cables or at the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha p4500 protect lights do not go off at power up
You only normally get that when the Volume over peaks, and the amp will automatically cut out to prevent it fron blowing the whole P.A up.
If you know it was working fine before the wires were twisted together, then best try undoing what was done, and making sure that the Amp's Volume is turned down to minimum.
Dec 02, 2008 | Yamaha P4500 Power Amplifier 2-Channel
P4500 yamaha amp
first check your input cable-disconnect it and check if the problem finished---you will have a problem in input(cable or device)-start with another cable then your input device.
if the problem still check your out put cables(speakers cables)for short circuit or touch the bare wire with amplifier body.-try to clean volume controls with spray contact cleaner---confirm good connection in amplifier rear and in speakers rear.
Aug 25, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha P4500 Power Amplifier 2-Channel Bridge mode
im from Yamaha service before and i know this model can handle as low as 2ohms per channel. I have to check on my manuals though if bridged. i dont see any reason why it cant. and it has a bridge option input stage... let me get back to you again in the days to come.
or email me redrivera0314@tyahoo.com
i have a service manual to check on this. got to dig on my closets..
Mar 14, 2007 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha P4500 Power Amplifier 2-Channel Logo
1,617 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
