Question about Powercom BNT-600AP (bnt600ap) UPS System
UPS Turns ON and OFF by Itself.
Hi, I am using Powercom 600VA UPS for the past 4 years.Recently my ups is switching on and off by itself.I have replaced the front switch but there is no use.The same problem exists even now.What might be wrong with the ups?
  • Mosu Mar 18, 2009
    160V
Hello, phanivyas
check R85=0.1 Ohm/5W
If your UPS is switching on and off by itself with a beeps continuos, you need to replace the electronic board.
Best regard
Juan Mora
Posted on Feb 21, 2008
    New Friend:
  • 3 Answers
You may need to change the battery within the battery backup. The normal lifetime of a battery is roughly 3 years.
Posted on Jan 29, 2008
My powercom ups canot power on
hi there check the fuse and let me know the condition of that.
Jan 19, 2011 | Powercom BNT-600AP (bnt600ap) UPS System
Hi! Per our UPS problem is when open 3 or 4 hours, then auto Off the UPS. please let me know what the problem. And i need to change the PCB board or just repair the PCB board? Thanks Regards
If you unplug the unit and it powers your PC for 3 or 4 hours then turns off, it is because the batteries are empty and this is normal. If it is plugged-in with power and shuts itself off after a few hours, then the battery cells may be in need of replacing. You can purcase an inexpensive replacement battery here: http://www.upsforless.com/browseproducts/Powercom-Replacement-Battery-Kit-BNT-500A-BNT-500AP-BNT-600AP-BNT-800AP-KIN-425CSU-KIN-625CS.HTML
Dec 01, 2010 | Powercom BNT-600AP (bnt600ap) UPS System
I am using UPS of 600VA from prolink company,recently my ups is not giving any backup when the voltage bling ,the moment power is off it is getting switched off.but when the power full off then it gives...
It sounds like the battery in your UPS has aged to the point of failure. The life span of these batteries can typically range from 1 to 3 or 4 years.You should be able to remove the battery and write down the make and model. If possible, have the UPS vendor check out the unit for you. Check to see if your UPS is still under warranty. The cheapest source for replacement batteries is your local electronic surplus store, if there is one in your area. There may be other vendors who sell used UPS's. Otherwise, do an internet search for either the UPS manufacturer, or for the battery manufacturer to check on replacement battery cost. Be prepared for the battery replacement cost to be perhaps half the cost of a new UPS unit. Also, know that the problem may be with the UPS itself. Sometimes, UPS units go on sale for prices that approach the cost of repair, or battery replacement.
Either way, I think using a functional UPS is a very smart bit of prevention to do.
Please let me know how you make out.
Oct 27, 2010 | Computers & Internet
My powercom UPS model no. is IND601A.It shuts down on its own with beep going off.the device doesn't function at the first attempt but it takes 4-5 attempts to get started.I mean to say when press start...
Please open and check your battery. possible that it has gone weak. Put the set on and do not switch off as the batttery needs the trickle charge to keep fit.
This is do-it -yourself site and we do not recommend any company.'But check for a search for Powercom Power supplies.. Might help.
Sep 02, 2010 | Powercom Computers & Internet
I am using UPS of 600VA from zebronics company,recently my ups is not giving any backup,the moment power is off it is getting switched off. plz help me out,vat should i do now?
I would first check the connections to make sure the battery is connected. If it was working before it should be connected unless someone has removed it for maintenance, etc.
Other than that my next suggestion is more than likely either the battery is bad and not holding/accepting a charge, or the charging circuit in the UPS itself has faulted and is not sending charge voltage to the battery.
May 03, 2010 | Computers & Internet
Ups after 1 hr automatic disconnected and on only battery mode.
I have to believe that the problem is in the smart chip, with the software that monitors the power. There is a very good chance that you have a slightly higher input voltage then normal. You may have to contact Powercom.....
I don't think you are in the USA...I sell Powercom and I don't recognize the part number. I think this is simular to the IMD 625 Va UPS sold here in the USA. The imperial model had a defect on the smart chip two years ago here in the USA, and I figured it out for the MFG, so maybe that same chip is acting up for you. Besides, the 600VA size should be too small for you know. You should upgrade to a 1000VA. It will handle the load much better.
Aug 26, 2009 | Powercom Computers & Internet
UPS shuts down when the mains is off.
Hi
After 3 years, i would by a new UPS...
The battery will have to be changed if you want to keep the old one.
What i've seen mostly here in south africa. When the battery life has ended they customer opens the ups and takes out the battery and then connects a car battery to the terminals. The then close the ups and let the car battery stand outside the ups.
Hope this info helps...
Apr 26, 2009 | Powercom BNT-600AP (bnt600ap) UPS System
Power issue?
Hi, More often than not, it is the internal battery of the UPS that causes switching off. In some instances it may be that too many devices are attached and drawing power from the UPS. In rare instances, it is the electronics controller that is at fault. 1. Since checking the battery involves opening the unit, you may be better off seeking the services of a qualified professional (there are dangerous voltages inside the unit even when off); 2. Try removing some of the devices connected to the UPS and simply leave the PC itself connected to the UPS. All others may be plugged in to the mains; 3. Checking if it's the electronics would be similar to # 1. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 13, 2007 | Powercom BNT-400AP (bnt400ap) UPS System
Powercom BNT-600AP (bnt600ap) UPS System Logo
738 people viewed this question
Top Powercom Computers & Internet Experts
David Payne
David Payne
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
