Microsoft Xbox 360 Console Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 360 is not reading any discs - Microsoft Xbox 360 Console
Anonymous
Level 3:
Genius:
  • Master 1,093 Answers
  • Posted on Dec 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1093
Questions
0
Helped
146238
Points
2211
If your Xbox 360 is not reading discs this is because the sensors on the back of the drive have overheated, to fix it you need to send it in to Microsoft or you can fix it yourself with a good Xbox 360 Repair guide
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
384
Points
15
The reason is because there is a lazer inside your xbox that read's the CD's it is weak and or has dust on it. I have the same problem what I normaly do it open the driver and blow into it acupple of times then close the driver with no CD in it, open it back up insert CD and close. Sometimes it works sometimes it doesnt its the luck of the draw. If you dont feel like putting up with it you could always send it into xbox :/ PAIN!!
Why won't my xbox read the game?
IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
Xbox chewing up discs occasionally
The xbox 360 has a faulty disc drive that will occasionally chew up discs. The reason is that if you move the xbox while its reading a disc it will scratch it to hell but if it does it without movement during reading the disc you need to get a new xbox 360 or send it to microsoft
Why wont my xbox 360 elite read discs? i put disc in and it comes up reading and then open tray
My only questions are does the console say the discs are damaged in any way? and is the console standing up right?
If the discs are scratched in any way then that might cause the 360 to not read the disc and sometimes having a console play the disc upright (example of upright 360) for a long time can cause dis function when trying to play discs, so try playing the discs with the console on its side (side example) These are my solutions to the problem but you can try these: Solution 1 Solution 2
Xbox 360 Console: I've had problem with my Xbox 360 reading my discs...
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email [email protected] for a pricing for repair.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
My xbox 360 is not reading any disc. I tried cleaning the dics, I tried new disc and still not reading disc.
If your Xbox 360 is not reading your discs you need to stop the heat build up on the receptors at the back of the dvd drive.
To do this you need an Xbox 360 Repair guide or to send it back
3answers
My xbox is not reading my discs
xbox wont read any discs and there are no red lights
1helpful
My xbox 360 only pays old games(like pgr3) and not new games(like need for speed shift)
The laser in your XBox 360 is probably going out. When lasers start to fail, the first discs that stop reading are newer, dual layer, discs. Single layer discs will still read. As the laser wears out, single layer DVDs will stop reading but CDs will continue to read. Eventually, everything will stop reading and the laser will die.
You can find lasers for the XBox 360 all over the internet. Installing them isn't easy though.
1helpful
2answers
Not reading any discs
My xbox is not reading discs. please help.
360 game reading problem
ive got the problem to on some games eg. assassins creed just bought it, it keeps saying read disc error its not the disc its the xbox itself im gunna try and take it bk now.
p.s.the problem is with the memory unit on top.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
