Question about Husqvarna Viking 1
Broken Cam in a Husqvarna 2000
Hi from Australia, we have a husqvarna 2000 with a broken cam. I can see the broken cam it is visible through the opening where you insert the plastic stitch cams. My question is : How do you remove the broken part? Do you remove the large screw in the centre of the cam or does the cam simply slide out once other items have been removed? Thanks Don
  • 69 Answers
You can find a video on how to do this at Sewingnz Youtube channel playlist
Posted on Jan 11, 2012
There's a guide that holds the cam stack in place. There's a screw just to the left of the cam that needs to be loosened. This is spring loaded, but it should wedge against the stitch length arm and not come out completely. Once this is loose you should be able to pull the cam stack out. You just need to make sure this guide makes it into the groove of the new cam stack when you're inserting it.
Posted on May 12, 2008
My zig-zag no longer works on my Husquarna 6020 how can I fix it
if the zig zag no longer works then the machine would have to
be taken to a sewing machine repair shop to see if a gear or cam
is worn badly or broken that needs to be replaced.
Apr 11, 2013 | Husqvarna Sewing Machines
Cannot snap decorative stitch cam back in
What model machine are you using? If it is one of the 2000 series machines (might be labelled 6430 or something else but starting with 6000), from memory you need to align the knobs on the front to the "dot" before you remove or insert a new cam.
Jan 13, 2011 | Husqvarna Viking 1
Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Apr 23, 2010 | Husqvarna Viking 1
I need to find a part for my 1964 viking 2000 colormatic. It is the fixed cam (plastic) that is cracked.
That part is called the "permanent cam" the part number is 4111595-01. Your local Husqvarna Viking dealer should have them. You can locate your closest dealer by visiting their web site, they have a dealer locator. Just put in your zip code and they'll show up.
Oct 18, 2009 | Husqvarna Sewing Machines
Ordinary straight stitching/Husqvarna 2000 SL
ordinary straight stitching is normlly the first button (only one) in the stitch selection area. Look for symbol/picture showing a vertical broken line on the displays.
Sep 02, 2009 | Husqvarna Viking 1
CAM broken
The information you were given is unlikely to be true, unless the part was no longer available (which would be pretty unlikely if the machine were new as you stated). If you can provide a model number AND an indication of what cam your repairman was referring to, I would be happy to check on that part's availability.
May 06, 2009 | Husqvarna Viking 1
Husqvarna 2000SL Sewing Machine
The plastic dries out over time, and this is what may have happened. You could probably remove it by exerting a great deal of force, but will most likely break either the cam itself or the part where the cam is inserted. You could try squirting a little lubricant (maybe Tri Flow?) and leaving it for a while to penetrate before trying again to remove the cam. Otherwise, it would be best to take it in to a repair shop where an expert can work on it and maybe replace any parts that are no longer working properly.
Pamsquilt
Oct 10, 2008 | Husqvarna Viking 1
Sewing machine
Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jul 13, 2008 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
787 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
