Question about Vacuums
LG Cyclone Vacuum Cleaner Model No VKC902H
I have had the above vacuum for 6 months, it came with a power head tool and the tool has stopped working properly. It been cleaned and still does not rotate, as its the only head I cannot use the hoover. How Do I get a new one?
Kind Regards
Dianne Cole
swanage
Dorset
UK
info@swanagehaven.com
  • 46 Answers
There is a small belt inside the head ,remove screws and disasemble carefully. and replace /refit belt
Posted on Feb 09, 2008
When cleaning the cyclone head can this be flushed with water?
Hi Len, it's Jack at Dyson.
The cyclone pack on your DC14 should never be washed, flushed with water or submerged. Any residual water left within the assembly could cause permanent damage to your vacuum not covered under warranty. It could also contribute to an unpleasant odour from your machine in use.
To clean the clear bin and shroud, you can remove the clear bin from the cyclone pack using the catch on the rear of the cyclone pack, as shown below. A soft brush or dry cloth can then be used to remove any clinging fluff or debris from the shroud. Gently tapping the cyclone pack will also help remove any clinging dust particles.
You can also rinse or wipe the inside of the clear bin with a damp cloth to remove any dust particles, but make sure it's completely dry before reassembling.
I hope this helps, but if you'd like any further guidance on maintaining your vacuum, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 11, 2014 | Dyson DC14 FS Telescope Full Kit HEPA...
DC17 suction motor stopped
It could be that your cyclone needs to be replaced. Depending on how the unit was cleaned (the cyclone in particular). Some people who service these machines wash the cyclone with out completely dismantling it, they just fill it with water and shake stuff out of it. This can cause debris inside the cyclone to become lodged causing clogs. If after checking for clogs and if your changeover valve is working (the piece that moves back and forth on the side of the machine when you pull the handle back to vacuum carpets) and the machine is in the upright posistion and the hose doesn't work, then you probably have a cyclone problem.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 10, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need a set of carbon brushed for an Electrolux "Cyclone Power" "Stairmaster" upright vacuum cleaner. Where can I find these?
They're usually ot find in the "electric article" shops, where you can also buy power tools, and stuff...
Apr 26, 2011 | Electrolux Vacuums
I have a Dyson DC07 and it has lost suction. I have checked the belt, cleaned the circular filter and emptied the dirt chamber. The hose still has plenty of suction but I can't use the hose the vacuum...
Here are some things you can check.First you need to see if the problem is with the suction or agitation.If the suction on the hose for using the attachments is low you either need new filters a new cyclone(they are not cleanable) or it is clogged.To check for a clogg remove the cyclone and turn on the vacuum cleaner.you can put your hand over the suction side of the handle tub and feel if it has suction there.Reinstall the cyclone and again check the hose.If it is the same you don't likley have a suction problem you have an agitation problem.The 2 belts on the DC07 are part of the clutch and when they are strectched to a certain point (3-5years) the clutch needs to be replaced.you can check the clutch by turning on the vacuum cleaner and applying slight pressure downward on the front of the vacuum head.If the vacuum makes a loud ratcheting noise or you can stop the brush from turning the problem is most likely the clutch.One last thing is to make sure the bottom plate is on correctly I often see a misaligned bottom plate and the brush dosen't hit the carpet so it dosen't pick up.  www.sewvac.com
Jan 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i clean my dyson root cyclone vacuum cleaner
believe it or not i would use a long paint brush with a opened bin linner,, to collect all the dust,,,
you can wash your blue filter in plain water and leave to dry as u would pots n pans on the side,,
when u have cleaned the area around the cyclone.. close your eyes and blow into the cyclone.. then use another large hoover to remove access dust and rubbish that was in the cyclone,
hope this helps reguards lee.
May 01, 2010 | Dyson DC16 Root 6 Bagless Handheld...
It doesn't have any suction power. What do I look at first?
first you will need to look at the filters the filter on the right hand side of the unit is washable and can be cleaned the filter under the bin should be replaced every 6 months, if this does not improve then remove the bin assy from the unit and open the flap at the bottom and with a torch look down the middle of the cyclone you may find a blockage,also under the the cleaner head itself take a look at the clear hose as this may have a split of may even have fallen off hope this helps
Nov 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The motor LG model VKC902H either shuts off or blows a fuse
There will be repairs as it is either a short in your wiring or your armature brushes or brush on one side of the motor is worn down to low, check to see if covered by warranty as these two issues are not normal wear and tear over a period of 20 months unless you vacuum 3 times a day!
Aug 21, 2009 | Vacuums
Vacuums Logo
582 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
